Ohio Rider
My clutch rattles at idle. I give it just a little throttle and it stops...any ides what this could be and what is the fix...very annoying...
snowy1
its normal you can turn up the idle or live with .
kinger
There was a recall on my Dad's 05 vector for clutch rattle and they replaced a bushing with a larger one, would the same thing apply here?
hotrodsrx
Sync the carbs. This can help as well.
yamrx1
Updated slider kit for your clutch from dealer may be in order
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
As yamrx1 says there is an updated slider kit for the '03 primary clutch. I have it installed on my '03 RX-1, it did take off some of the rattle, but not all. There will still be some noise which are coming off the sprockets on the gear reduction inside the engine, this rattle is normal on the '03 rx-1. These sprockets where cut different on later models and reduced the rattle significantly.
Blue shadow
8ES-SLIDR-KT-OO
Ohio Rider
Thanks Blue Shadow. I orderd the kit from my local Yamaha shop...only $12.95...money well spent if it reduces some of the rattle... after I install it and find out how much it actually reduced it...I will ever so slowey raise the idle to make up the difference.
Neonblue
- Aug 17, 2006
Please post back when you install it. I've got the same issue. Thanks.
Ohio Rider
It's on order now and I will probably ne istalling it in October. I will post right after I install it neonblue!!
whits-end
Gentlemen,
Once again:
That kit will help somewhat, but much of that noise is coming from the gear reduction.
Synchronize the carbs! Honest! It works wonders. (Use a manometer)
Beyond that, increase the idle speed a little, and that's as good as she gets.
Once again:
Ohio Rider
Whits-end
How difficult is it to syncronize the carbs? Also, after installing the slider kit what would be a good idle speed?
whits-end
Sorry for the delay.
Synch isn't that hard, you need a manometer (water or mercury stick) and patience. A 4 tube unit is easiest.
There is a thread with a good procedure, just do a search.
Idle speed is personal preference, but I could cure most of the rattling and still keep it down to about 1800.
whits-end
ReX
My 05 RX-1 started to rattle quite a bit last season. From reading here I also assumed it was partially due to the gear reduction and tried the "recommended fixes" (carb sync, idle).
As part of my regular maintenance I noticed the clutch spider slides were starting to get out of spec so I shimmed them for snug, but nicely sliding fit. The clutch rattle 100% went away - even at lower idle rpms (cold engine).
At least on the 05 RX-1 the clutch rattle (in my experience) is almost entirely due to worn spider slides in the clutch.
The o-ring kit might also work. I didn't install it.
After shimming the clutch and putting over 9000 additional kms on the sled, the clutch was still very quiet.
