rx12004
- Jan 4, 2017
- iles-de-la-madeleine, québec
- Yamaha rx1
Hi, i projet to swap my suspension on rx1 2004 for a sc3 2004 mxz 600. Need help to find a right place to drill the new front hole.
real
- Dec 24, 2015
- Ontario ,Canada
- Yamaha RX-1
I just finished doing that very swap ill take some measurement's for ya.Hi, i projet to swap my suspension on rx1 2004 for a sc3 2004 mxz 600. Need help to find a right place to drill the new front hole.
wyre345
I would like some measurements also. I'm going to do a swap in my 05 rx1I just finished doing that very swap ill take some measurement's for ya.
real
- Dec 24, 2015
- Ontario ,Canada
- Yamaha RX-1
Front Hole is 2 inches forward of oem and 1/2 inch lower,Rear plate removed made up new 1/4 aluminum plate 10 inches by 6 inches at top less on lower section .upper 90 degree bracket was moved rearward 2, 1/8th. Rear Axle Shaft hole is 2, 1/8inches from the bottom of floor board my machine is a 2005 rx-1 129 inch track works like a dream.send me an email and i will send picsHi, i projet to swap my suspension on rx1 2004 for a sc3 2004 mxz 600. Need help to find a right place to drill the new front hole.
