hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
having a high idle issue,idles at 1900 rpms. Just recently installed hindle exhaust air box mod and Pcv 5. Is there any adjustments in the pc5 for the idle or how do I get idle down
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You might want to check your cable routing. You might have disturbed it. I did a full MBRP exhaust, K&N's, OFT relocater & PCV with no change to my idle but I did notice gobs of arm stretching pull. Did you make sure it was thoroughly warmed up? Just wondering.
hognit09
- Mar 7, 2010
- beaver dam, wi.
When cold it's at 2700 and warm is 1900-2000 rpms
hognit09
- Mar 7, 2010
- beaver dam, wi.
So how do you adjust idle?
canoehead
- Jan 14, 2011
- NE, Alberta
You can not adjust the idle on a Nytro manually! It sounds like your PCV was not nulled when the map was loaded. I believe you are going to have reload your map.
canoehead
- Jan 14, 2011
- NE, Alberta
Any updates?
hognit09
- Mar 7, 2010
- beaver dam, wi.
I had high idle before the Pcv. Bought the hindle kit and Pcv used from another member here, so I didn't do anything but plug it in. There gotta be some adjustment somewhere
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Nope the stupid idle speed control valve that's electronic piece. It's all preprogrammed
MNBlizzard
Check the vacuum lines off the throttle bodies..bet you've got a hole/crack somewhere and sucking too much air.
hognit09
- Mar 7, 2010
- beaver dam, wi.
thanks i will check that out,prolly a pain in the *** to get at. is there 1 line for each throotle body or just 1 line
