MS-310
- Jan 3, 2008
- Nashville MI
- www.grantswoodshop.com
Well I know I read it some where around this site but I cant find how to sync the carbs on my RX-1. Also I know alot of you guys have done it so any little mods would help alot. I want to make sure I can keep fuel ran to it when I am doing it also. The sync tool I got from super tunner.....Dont know what one yet..
Thanks alot.
Jack
Thanks alot.
Jack
Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
You will also find a how to with text and pics in "rxrider's turbo garage" thread
http://www.ty4stroke.com/viewtopic.php? ... c&start=75
MS-310
- Jan 3, 2008
- Nashville MI
No Thunderlips it will not hurt anything.
Badsled...warm the engine up good before connecting the manometer. Make sure the engine idle speed once warmed up is between 1200 and 1450 RPM's. If it is not raise or lower the idle to this specification. Shut engine off when it is good and warm, then disconnect the 2 black hoses going to the #1 and #4 intake manifold. Connect these 2 hoses together as this is what operates your fuel pump. A small piece of tubing of some kind works nicely for this. This will prevent the pumps from going airbound thereby giving you a little more time to run the engine off of what is in the float bowls only. The other alternative would be to hang an auxilliary fuel tank up and use this as your fuel source by connecting these 2 hoses via a "T" to the auxilliary fuel source. If you are reasonably efficient, you can usually get the carbs synch'd before running the float bowls dry. Okay, so now the #1 and the #4 hoses are connected from the manomometer to the intake manifolds spigots located at the top of each manifold directly in front of the valve cover. Next, remove the black rubber plugs on the #2 and the #3 intake manifolds and connect the remaining 2 lines from the manometer to these. Note that the manometer (If you bought it from me anyways) is numbered. You should put the cylinders corresponding to the number for each number on the manometer. Start the engine and let it idle. if all 4 mercury tubes are even within a small amount or very close there is no need to adjust anything. Start by adjusting the # 2 carb to the #3 carb. The adjusting screws are located between each carburtor and are a phillips head screwdriver configuration. There are 3 phillips head screws for doing this. One is between carb 1 and 2 one is between carb 2 and 3 and another between carb 3 and 4. The reason there is only 3 on a 4 cylinder engine is due to the fact that when you make an adjustment, you are adjusting one carb up and one carb down. Perform the same procedure for the #3 and the #4 carbs. These phillips head screws can be seen by looking straight down between each carburetor. If a cylinder is showing high on the manometer, adjust the screw counterclockwise. Note that you will not only be lowering that carb but also raising the one next to it so slight movements are only necessary. If it is low try moving the adjusting screw clockwise. Give then engine a few "raps" of the throttle between each adjustment to allow the engine to "stabilize" to the new setting. High revs are not required so be very careful not to allow the clutch to engage. A quick tip too...when you press down on the screwdriver to adjust each carb, you will actually change the snych due to the fact that you are pressing on the adjustor. Don't let this fool you. Make a small adjustment and remove the screwdriver pressure from the adjusting screw and give it a moment to respond to the new setting. Reconnect all your hoses to their appropriate locations and reinstall the plugs for the to #3 and #4 manifolds. Try to get the carbs synch'd within .19 PSI of each other. Also, it is good to know that your valve lash is within the factory tolerance. Adjusting valve lash changes the manifold pressure thereby changing the carburetor synchronization. You are done.
If Mr. Sled would like to copy this into the tech section...be my guest.
ger...I like the mercury type. They seem to be a bit more sensitive than the vacuum type. This is my preferance though and I am sure the vacuum type work well too.
Traildemon...I have the mercury style in stock and they sell for $77.95. They are up a few dollars from last year because they have to be shipped as a "hazardous chemical" due to the mercury that comes with the kit.
Good luck! Hope this helps you guys out.
Freddie
_________________
ECP...experience builds a better product and service.
What hoses do you connect to the tee to add fuel? As I see you want to connect the lines from the 1 and 4 carbs to fuel....isnt that the pluse to make the fuel pump work....???? or am I just dumb?
Freddie
_________________
