canadianhunter
Watch this video for how to easily remove rusted nuts or bolts
http://www.liveleak.com/view?i=ba2_1475277076
YukonMP
- Dec 25, 2014
- Yukon Territory
Can't wait to try that one. I picked up a can of anti-seize on Mooseman's recommendation but I know this is going to come in handy. And my friend's are going think I am so smart.
Thanks for posting.
Thanks for posting.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Ya pretty sure that won't work, not hot enough just use torch
Thunder66
- Nov 5, 2015
- Holly Michigan
- 2012 Yamaha Apex
PB Blaster and patience!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Melting BeesWax into the threads also works. Also good for noisy serpentine belts on your car/truck, rub the wax on the belt (carefully) with the engine running, removes all belt noise.
Team Lazy
The comments are priceless. They called him every name in the book but still didn't even make it to the MMA t shirt and bare feet!
I say it's still worth a try anyways.
superfan75
I'll have to try that the next time I have trouble with a rusty bolt.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Kroil. That's all GE machine maintenance uses.
But I'd like to try that candle thing.
i have used the candle on old crusty bleeder screws and gotten them out 95%of the time. it does work.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Those bolts in the vid aren't that bad. But the candle thing does help alittle. Badly rusted bolts/nuts need 2 be almost glowing red hot 2 come off
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
map gas and PB blaster get it hot enough that the PB blaster creates a plume of white smoke when sprayed on the part spray heavy and it comes out like butter. Have not lost a bleed screw since using this method. have to get it hot enough is the key.
