exttrimmer
- Jan 24, 2016
- southern ontario
- Yamaha rx-1
Hey All.
Picked up my rx-1 last year. Everything is fine as far as operation. Added the WRP seat mod and had to add a removable jack seat for the odd fishing buddies.
My question is where on my slider frame is the best place to add 12" ice scratchers. Would there be enough room in front of double slider wheels or should I add behind them.
OR
Should I ask for a pic of what you guys have done to add to your skis
Sent from my SM-T530NU using Tapatalk
OR
MUSKOKA RX1
Mine is located right behind the double slider wheels. Hope this helps you out!
Sent from my SM-N900W8 using Tapatalk
Fortress
The farthest forward possible is the best, more snow to the track, we use Yamahas Tric ice scratchers mounted to the a arms, then I just tuck them up in the a arms when I don't need them, but other systems work good too, I personally prefer ones you can reverse with.
exttrimmer
- Jan 24, 2016
- southern ontario
- Yamaha rx-1
Thanks Guys !!
Ended up with the Yamaha tric scratchers
