Koeckman
IMO, Cheap Insurance..............
Oil Filter......................................$10
New oil........................................$20
New sled after blown motor...........$12,000
Your time spent doing the job right learning exactly what need to be done for next time................$Priceless
2008 Nytro RTX
Guys the oil is changed and has been changed for a while now,Thanks for trying to help me though.
Daranello
Suspended
also manual also says only at 2 quarts, start and run for a few minutes, then add the remainder to top off
arteeex
Daranello said:also manual also says only at 2 quarts, start and run for a few minutes, then add the remainder to top off
I bet you stop and ask for directions when your lost too.
Daranello
Suspended
arteeex said:Daranello said:also manual also says only at 2 quarts, start and run for a few minutes, then add the remainder to top off
No getting lost is half the fun
So what is the exact amount of oil you guys are having to add when all said and done?
Sled Dog
I do only an idiot would run around lost because of an over inflated ego. When your lost your lost! Admit it get help and learn from your mistake.
jvmaxwell
- Jan 10, 2011
I cannot seem to find the filter number in my manual for my 08 fx nytro rtx. any suggestions?
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
kn147... amazon.com ussually the best price.
yox185
jvmaxwell said:I cannot seem to find the filter number in my manual for my 08 fx nytro rtx. any suggestions?
5DM-13440-00-00 Yamaha filter
MadMax2011
changing your oil is not too bad, except..
I did my oil (and filter) change for the first time. I carefully read the instructions posted here and I also read the instruction manual.
One thing that was not mentioned either place (not that i saw , anyhow) was those nifty little plastic rivets yamaha uses to hold the lower body panels . They Suck. I broke quite a few getting them off.
I reccomend that when you buy your oil and filter, do your self a favor and buy replacement rivets for the ones you are about to break.
Also, unless you are a "strict factory original" kinda person, I reccomend that you dont use the same yamaha ones that come on the sled. Instead buy about 20 Honda rivets P/N 90653-HC4-900. They are .70 cents a peice and well worth it , as they are very easy to re-use.
I dont live close to a dealership, so this little problem added about an hour and a half to the job.
So, do yourself a favor...
Supa Dexta
Don't try and only pry one side, both sides need to be lifted at once and they will work as they are supposed to.
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
my vote is to redo the oil change since you just contaminated the fresh oil with all the dirty oil that you left in the engine,also you can buy the plastic rivets that hold on the plastics at a hardware store for about 30 cents a piece,good luck
MadMax2011
i tried prying every which way to get the stock rivets off without trashing them. they still broke. the honda ones are thicker material designed to be reused repeatedly.
thanks.
thanks.
09Nytro_XTX
What is the suggested oil weight to use? I see many different weights on amazon
