dylanjen9
Have a 247 triton prestige and it seems a lot of snow blows inside trailer when driving. I know there is holes all the way down in the tie down rails. Is that were all the snow comes from and has anyone fixed the problem?
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Where is the snow? Vents are sealed while running down the road? Rear and side door seals intact?
dylanjen9
Believe it blows up underneath through the tie down rails because they have holes in them all the way down
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
If it's a channel and you need to get in those holes get some foam in the Home Depot weatherproofing stuff for filling window gaps around ac unit, it's like 2x2 maybe 5 feet. Grainger has bigger longer pieces or get some foam for rain gutters to keep leaves out. If your set on where you tie down foam it with DAP window foam in a can. Way easier to remove than great stuff if you have to
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
Cut up a rubber floor runner and run strips over the holes
