pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
Trying to find a base map for a 2012 Apex with a MPI supercharger running 6-8 PSI and a PCV. Any help is appreciated. Thanks, Mike
Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
this one is for 10-12 pounds of boost if that helps
AreApex
- Feb 27, 2018
- Geilo
- Norway
- 2006 Apex MPI stage 1.
Hi, just bougt a PCV for my MPI stg1 06 Apex after the GEMS stoped working. there are 2 files: Fuel and Fuel (presure) witch one do i send to the PCV?? both? trotle an presure...
pdrmike
- Dec 13, 2005
Yes,send both!Hi, just bougt a PCV for my MPI stg1 06 Apex after the GEMS stoped working. there are 2 files: Fuel and Fuel (presure) witch one do i send to the PCV?? both? trotle an presure...
AreApex
- Feb 27, 2018
- Geilo
- Norway
In eny special order? I have sent the one with pressure, can i just send the other one then??Yes,send both!
pdrmike
- Dec 13, 2005
My files I send have fuel and pressure maps together. If you have 2 separate files, you should be able to use one or the other. Just look at your air/fuel gauge after you send one to be sure.
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Guys to clarify PC either run on pressure = 1 to 20 lb of boost
Set up your units based on how much boost pressure your using
Or
Fuel
Not both
Cancel on side if you have both running make notes of your setup first
There’s a great video on Dinojets website for reference
Or
Fuel
Not both
Tiny
- Mar 14, 2022
- Kitchener
- 2011 yamaha Apex XTX
Hi there, question about your map. I notice your autotune target is for TPS%, with boost aren't you suppose to use pressure%? I do see pressure mapping just the numbers are confusing. Sorry I'm a newbie with boost trying to learn lol
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Hi Tiny
Get onto power commander website for setting up your tunes. You’ll notice they either set up based on pressure or throttle position.
It’s definitely a learning curve for you based on your set up
Having autotune is a major bonus.
What seems to be the issue?
Tiny
- Mar 14, 2022
- Kitchener
Hi when I compare our maps, the pressure % portion makes sence which my autotune is set for Target on pressure not TPS%. But when I compare our TPS% values mine seem to be way off lol. I guess what I'm wondering does my pc5 use both maps TPS n Pressure to run the fuel system or is it one or the other I select for autotune. Man I'm confused lolHi Tiny
Tiny
- Mar 14, 2022
- Kitchener
Also which is better for boost, I was under the idea you want to build pressure fuel % mapping with autotune. When I look at at my mapping it seems the tps% and pressure% would be fighting each other maybe? Sorry not doubting your map just trying to understand the whole thing. I'm old school carb kinda guy lol.
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
They both do the same thing with your PC plugged in select one or the other and go from there. How much boost are you running?
Tiny
- Mar 14, 2022
- Kitchener
Running around 6lbs mpi S/CThey both do the same thing with your PC plugged in select one or the other and go from there. How much boost are you running?
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Tiny call me on my cell 905351 2103 if need be
