Tom Hearn
What looking to squeeze a few more ponies out of my nytro, and aside from turbo or super chargers what's kinda upgrades are recommended, planning on a barker pipe but haven't really looked much further than that
Lman69
Guest
- Nov 5, 2013
Barker pipe is a nice upgrade!
Sent from my SM-T520 using Tapatalk
Tom Hearn
It says a good hp gain but do I have to get the ecm flashed for the pipe to make the hp? I'm new to the nytro but have an R1 and when it went to a yosh pipe it recommended an ecm flash
Lman69
Guest
- Nov 5, 2013
Didn't get ECM flash but do run a power commander to manage low end lean running.
Sent from my SM-G930W8 using Tapatalk
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
Ulmer K&N intake kit, PCV, and an exhaust along with clutching makes a pretty good difference, about the best you can get without going forced induction.
GYTR GEARHEAD
get the hurricane performance package i heard nothing but good thing about it come with full exhaust mod air box and power commander with map its make that motor pull way harder most guy gain around 10 mph and a lot of trottle response from what i could read
Hurricane kit is money well spent. 18 hp gain, fuel economy is as good as stock and runs on 87 octane, losses about 13 lbs off the rear, no exhaust donuts to worry about and pulls hard from 0-100 mph with proper clutching ( I recommend Drag n Flys with Turks black spring set up).
Barkers exhaust is nothing but loud...and anyone who believes their 12 hp gain is sadly mistaken. Slip ons are proven to make 2-4 hp across the board. Been there and done that
wowchad
- Feb 21, 2014
- Milwaukee'ish, WI
- www.tewco.com
- 2005 F6 - 2009 MXZ 800R - 2010 Nytro - 2015 ACE - 2016 MXZ 1200X
- Milwaukee'ish, WI
- http://usa.cvtech-aab.com
Do most full exhausts eliminate the exhaust donuts?
MBRP, SLP, Hindle etc.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
My buddy did the hurricane full upgrade this year with Dave's clutch kit as well. It really walks away from a stock nytro on top end and clutching is much better than stock.
Nope....Hindle is the only company that eliminates the donuts
devilnabludress
Hurricane kit with clutching all the way! Best upgrade other than forcing in the air!
This all depends on how much you intend on spending. I put the Schmidt Bros stage 2 clutch kit on and though it isn't a power upgrade it sure felt like it over stock. However when it comes time for power upgrade for me from all that I have read there is no better HP for your dollar than the full Hindle System. Barker is located over by me and I ran a guy on the lake when I got my nytro stock to stock and he was the same size as me. only difference was he had the barker on his and I got him by half a sled 6 times in a row. All he got was a headache there is no way that the barker is any HP gain. Just weight loss and db gain.
Tom Hearn
Well no doubt if your talking a full hindle system over a slip on barker, that's where the biggest gain would Be I'm guessing is the header pipe, as I said I'm new to the nytro but I know when talking bikes a full system will always get more power than a slip on pipe
Tom Hearn
What's the cost? Looking to do a few upgrades while I'm down for the season, I'm actually at looking at picking up a second nytro, same year but the 144" with 3,200 kms that will be my guinea pig me thinks
GYTR GEARHEAD
Hurricane Hindle Power Upgrade for the Nytro goes for 1050 $ usd and the clutch package goes for 500$ usd
