lhdriller
Hi Guys, Looking to see how many Km's/Miles before the break in process is complete and top speed can be expected. I've got 300kms on now and top RPM seems to be 8500, I've hit 175km/hr or 108mph. I've been beaten by an Apex and Polaris 800 on top end so hoping that it will continue to improve.I find I could use a little more lug on the track in powder. I was thinking on putting on 1.75" track and wider skis.
Any comments or different setups?
johnnysnowking
500 miles. It gets faster and faster. But check your track and chain religiously
fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
1050 miles new belt and cat rollers and on hard pack/ice trail it just hits a wall at 110. I have heard this from a few I talked to this weekend. I've seen max rpm of 9200-9350. Needs gear I think
69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
I hit 114 mph on gps and was still accelerating. Turning 8700. Beats every 800 I've raced.
Sidewinder146
- Jan 10, 2017
- Newfoundland
- 2017 Yamaha sidewinder
Seems like it's normal, my top speed is 99-100 on the speedo, just before the belt blows apart ! I have 700 miles on mine.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
Stock my sled did 118mph gps with about 160 miles on it. But it's not stock any more.
johnnysnowking
Exactly what happened to me. I hit the 500 miles and said finally. So it went to 108 and pop. Now it's eating belts like a fat kid eats cake in a cake factory.
1100saber
- Dec 17, 2016
- northern ontario
Something wrong. I have about 550 miles on the original belt. Ran 127mph twice, and 129mph gps this weekend...and belt still good.
johnnysnowking
Something wrong. I have about 550 miles on the original belt. Ran 127 twice, and 129 gps this weekend...and belt still good.
It's going in. Needs something adjusted. Sure it's nothing serious I'm just on a pack pack trip in the U.P. So when we get home and I just stay out of the throttle for now.
TurboWinder
- Jan 15, 2017
- Plainfield IL
- 2017 Yamaha Sidewinder
Oh man I hope this belt blowing is not an issue. I just sold my Cat F1100 Turbo because it ate belts to get the Sidewinder.
Sidewinder146
- Jan 10, 2017
- Newfoundland
Get ready to eat more belts !Oh man I hope this belt blowing is not an issue. I just sold my Cat F1100 Turbo because it ate belts to get the Sidewinder.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Thought the yammie clutch system was supposed to be improved over the cats??? I only have 45 miles on my sidewinder so belt still good. I'm not liking all the problems I'm hearing about these winders
lhdriller
What mods have you done?Stock my sled did 118mph gps with about 160 miles on it. But it's not stock any more.
1100saber
- Dec 17, 2016
- northern ontario
EVO stage 4. Sandale 3" Hyperflow
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
You guys are having roller and spring binding issues,by the sound of it,look at the 3 rollers on your secondary helix,see if any of them have flat spots on any of them,than take your secondary apart and check for paint rubbed off on the wire of the torsion spring,if it has paint removed,it may be binding. if your rpms are spiking to 9200-9300 you are binding,and building rpms,and may blow your belt if you do not cure this problem,also look at both clutches,see if there are belt marks on either one or both,where it is slipping,remove your belt inspect it,mark your primary clutch to see how far it shifts out under full throttle runs of at least 1000-2000 feet,by than you should be topped out,and stop check clutches for excessive heat,and belt,you should be able to hold your hand on both clutch faces if working correctly,and even belt,if they are smoking hot,you have issues,take to dealer.
- 40K
- 32K
