spike55304
- Feb 14, 2010
- Minneapolis
- 2018 Sidewinder XTX 137, 2014 Viper LTX SE (turbo), 2011 Nytro XTX
- Andover
Hi all-
Just installed a MPI 180 on the Viper LTX-very fun! I have an Ulmer kit but can't get a hold of him for updated settings. Assuming the weights need to be heavier by a bunch. I ride around 1500 ft elevation in MN. Anyone have the set up for that? Also, is the engagement pretty smooth on low end? That is what I am looking for. Thanks all!
spike55304
- Feb 14, 2010
- Minneapolis
- Andover
Is there a hump on the supertips?
spike55304
- Feb 14, 2010
- Minneapolis
- Andover
Anyone have the ulmer supertips weight set up????
are you running the base 60 gram supertips?
spike55304
- Feb 14, 2010
- Minneapolis
- Andover
Thanks for the response. Yes, I have the kit for the non turbo viper low elevation which I believe has the 60's.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Is 60 for the 180 super charger? Or for stock
how are you setup now? # of washers and location?Thanks for the response. Yes, I have the kit for the non turbo viper low elevation which I believe has the 60's.
spike55304
- Feb 14, 2010
- Minneapolis
- Andover
60 was for stock. I think it has 2 washers and o ring in tip now (hindle header and pipe was installed)
Are you runing ulmers k helix? Try 3 washers in the heel and 3 in the tip.
spike55304
- Feb 14, 2010
- Minneapolis
- Andover
Yes it is the k. Thanks for the help!
- 46K
