yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just looking for ideas what would cause engine to rev at 4000rpm at idle
Dinner
Vacuum leak.....or your throttle cable is hung up on something around the throttle bodies????
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I'll check both of your suggestions first thing in the morningVacuum leak.....or your throttle cable is hung up on something around the throttle bodies????
It's been a long day installing I'm pretty wiped out...lo
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I decided to go inspect one last time tonight and found one of the bov lines on the throttle body (center one) was disconnected would this cause high revs at idle?
Dinner
Lol I hear ya. Just make sure all vacuum lines are zip tied, all the vacuum port caps are installed and zip tied, etc. Should be something simple, your sled was running good before the install.
Dinner
It's possible since where that hooks up is a direct inlet into the throttle bodies. Not sure if that port is pre or post throttle body, but regardress it will be sucking in extra air. Hook the line back up to the throttle body nipple and give it a whirl! While double checking all other hoses and throttle cable.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Those dam ports on the throttle body have no Ridges on them to hold the hoseIt's possible since where that hooks up is a direct inlet into the throttle bodies. Not sure if that port is pre or post throttle body, but regardress it will be sucking in extra air.
In place
Dinner
In place
They should. My throttle body nipples have tiny little ridges on them. Then I use super tiny zip ties on all the hoses!
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Even if there is no ridge a zip tie will help. They have to be tiny though. Also if the hose was on something already just nip a 1/4" off it to get rid of the stretched part.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
ok I'm back at it!!
question the 3 new lines that go to plastic manifold on throttle body are connected to turbo blow off valve right??
what get connected to air box small barbed fitting?(eabc removed)
sorry I got it back appart and a bit confused
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
its showing it is capped is this correct
Dinner
The fitting on your intake plenum needs to run to the wastegate. And yes all the vacuum lines are connected to run to the BOV and boost gauge if you have one.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
So air box small line to silver part of turbo with rod(waste gate)
And plastic manifold from from throttle body goes where I can find where it hooks to
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Sorry and big thanks I'm a bit flustered
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I got it she started right up!!!!!!! NOW I' Pumped!!!!!!
BIG BIG THANK YOU DINNER
