yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
time to install Yamaha clutching that came with kit and put plastics on and try her out
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Wow this thing hauls a$$
Dinner
Glad you got it figured out! I was working so missed your later posts. You have the intake plenum (aluminium triangle that clamps to your throttle body) hose going to the wastegate on the turbo and your 5 "T" fitting for your vacuum lines hose running down to your BOV on the lower front left side of the turbo. If that's what your saying then yes your correct!
Also, I'm going to recommend a boost gauge at minimum. If you can afford it get Boost and AFR asap. I'd like to know how much boost your actually throwing at it!!
Also, if youd like... Turn the ignition on and hit the Mode button on the GEMS. Write down what numerical value each colour flashes at you. So push mode, write that colour and number. Push mode again, and so on until you have all your colours and numbers down! Once done you can just turn the ignition off. I'd like to see what the previous owner has it set at....
And your welcome for all my feed back!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Glad you got it running! Hope we can hook up next week and go for a run!Wow this thing hauls a$$
Dinner
Where is this snow you speak of in Ontario?
hellflyer
- Dec 2, 2008
Sudbury! next week Thursday a bunch of us are heading to the sportsmanlodge lodge.Where is this snow you speak of in Ontario?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ok just to be sure hoses are right
The small one from air box is going to the fitting on turbo right beside motor oil reservoir and throttle body tee going to turbo at the front of sled(manual calls it by pass valve)
I'll check codes shortly thanks again
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ok got gem controller codes
4 green
4 orange
3 red
5 green with 8 blue
3 and 4 red with 8blue
I believe this is the default setting for low elevation (under 3000 ft)
4 green
4 orange
3 red
5 green with 8 blue
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I have both afr gauges
And boost gauge but never installed yet
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hopefully the weather holds up warm weather coming for a few daysGlad you got it running! Hope we can hook up next week and go for a run!
hellflyer
- Dec 2, 2008
Ya! But not as warm as here!Hopefully the weather holds up warm weather coming for a few days
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yamamarc glad to here your sled is running good I might be heading up to Sudbury this weekend how are the trail conditions thanksHopefully the weather holds up warm weather coming for a few days
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey hammer right now trails are immaculate but we getting some warm weather next few days hopefully it doesn't mess thing up!!!! I'll let you know later this week on condition.. just be careful bigger lakes aren't safe yet (wanapetie lake panage lake)Yamamarc glad to here your sled is running good I might be heading up to Sudbury this weekend how are the trail conditions thanks
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Cool thanks for the reply keep me posted much appreciatedHey hammer right now trails are immaculate but we getting some warm weather next few days hopefully it doesn't mess thing up!!!! I'll let you know later this week on condition.. just be careful bigger lakes aren't safe yet (wanapetie lake panage lake)
And also did you get that mpi of kijij
I think that's the one I had my eye on lol
Dinner
4 green
4 orange
3 red
5 green with 8 blue
You are correct those are default GEMS settings...you should be good to go! And oh good about the gauges! Get them installed so you can monitor! And yes it sounds like you have the hoses hooked up correctly! Now enjoy your new mod!
