Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
OSP adjuster is opening up secondary b4 it bottoms out? What am I missing? I took spacer & shims out.....duh, now what
**sj**
call me...
Doc Harley
- Oct 17, 2016
- Here & there
Not a good answer! Hahaha!
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
I have tried calling, left a message, it's been two days, no call back.
Not impressed, after the sale service is what really matters, I'll take my business else where next time.
Sent from my iPad using Tapatalk Pro
Doc Harley
- Oct 17, 2016
- Here & there
I love my new Yamaha, I love my new Yamaha, I love my new Yamaha...... Snap!!!
Happy New year everybody!!!!! $(#+@/$('!:;_!"!!!!!!!
Doc Harley
- Oct 17, 2016
- Here & there
I guess I'm mad too......
Doc Harley
- Oct 17, 2016
- Here & there
Well this is what the adjuster looked like with deflection still too loose.
Bigbluemachine
- Apr 20, 2006
- NY
- 2017 Sidewinder RTX LE
2011 Apex ER
So given the ease of adjustment, should be easy to adjust for 8DN belt? Or am I wrong.
Doc Harley
- Oct 17, 2016
- Here & there
Idk.....but I needed to turn the outside collar counterclockwise. Which would have showed even move threads. Yuck! Right? Collar needs to on more!
silverram323
- Mar 24, 2013
Mine is barely flush. No instructions.
Doc Harley
- Oct 17, 2016
- Here & there
Mines FUBAR! Or is it just me.....
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Just add one .060 thou washer along with the two that came with it,and bolt it back togeather as it came from your dealer,and you will love the 8DN belt,at 55-60 bucks,ya its much harder,and a tad longer,but it runs fine.So given the ease of adjustment, should be easy to adjust for 8DN belt? Or am I wrong.
Doc Harley
- Oct 17, 2016
- Here & there
Are we supposed to add the two factory shims? I didn't put them in.....
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Ok I'm needing to adjust my secondary is there a special shim I need or can I use a regular washer? Need to add one or two more shims to get the belt back into factory specs area.
WINDER1987
I'm not impressed with the osp adjuster either can't the Allen threads into it super hard and still doesn't open it enough to change the belt I have to thread the adjuster in as tight as it goes to get it off and mine is the same it's right at the end I'm wishing I tried "the other companies" adjuster
