North Bay Ned 691
My brake light and running light quit working on my 2016 vk pro 2.
The light is an LED. What voltage should I have at the rear connector before it plugs into the brake light assembly. Should it be a full 12-14 volts?
Thanks so much to anyone that can help.
I am trying to avoid taking to the dealer as I only have 400 km on it....
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
Did you check the fuse, if it's blown might want to look under the handle bar pad, some of the 2017 vk 540 had lighting issues and it ended up being a chafed wire @ the Handle bars under the pad, not the fault of the sled but dealers not assembling sled properly! Cheers!
North Bay Ned 691
Is the fuse for the headlight the same as the brakelight...my headlights work fine....do you know what the voltage should be at the taillight?Did you check the fuse, if it's blown might want to look under the handle bar pad, some of the 2017 vk 540 had lighting issues and it ended up being a chafed wire @ the Handle bars under the pad, not the fault of the sled but dealers not assembling sled properly! Cheers!
I will check wiring under handle bar pad..thanks for the tip.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
I do believe it's a different fuse can't remember which one it is but, check them all! Cheers!
it should be battery voltage at the tail lamp. could be that it has just come un-plugged someplace it it was not seated properly on assembly.
North Bay Ned 691
Turns out the rear brake light failed - it was replaced under warranty.My brake light and running light quit working on my 2016 vk pro 2.
