bucknaked
- Jun 21, 2007
I have a 2008 Nytro that when you turn the key on nothing happens, no gauges, no clicks, no starter nothing. Batter has power you can turn the motor over by jumping the solenoid, fuses are good. Thinking it may be a relay, any idea's on which one to start with?
bucknaked
- Jun 21, 2007
Found the problem, corroded connection between the tether and the stock wiring harness.
