- Full Nytro 180 Supercharger installation instructions:
- Proper pulley installation instruction bulletin:
I have finally started my Supercharger build on my 2009 Nytro XTX.
I opened the box for the low elevation kit and started tearing the sled down.
The kit comes with ice scratchers and an extra tunnel cooler.
Also in the kit comes gearing and clutching if you sled is not geared for the Supercharger.
Removing the body panels and getting prepped for install.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Look at all the parts! This is going to a fun project. I'd be over there helping you wrench if I was closer. I will volunteer to be a test driver after your done.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
- 2013 Nytro XTX 2017 Sidewinder XTX
Can't wait to start mine!
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Wow, looks like fun! G.B.
Day 2: Found a few extra hours to work on the Supercharger build. Still tearing the machine down. Antifreeze is now out, Throttle body's are off and the engine oil has been pulled.
Few more hours today on the build. Pulled the mag cover and added the out-put shaft for the pulleys, added the rear heat exchanger, pulled the thermostat housing and added the new coolant transfer block as we as move water temp pick-up.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
nice excited to follow your progress.
Relocated the thermostat housing, relocated the starter relay, drilled blower mount hole and mounted the blower.
Another great day in the shop. I so wanted to go play in the boat today but decided to crank a few more hours on my build. I was at the shop anyway getting some things ready for Hay Days. Scott from Muffin Works popped over and gave me a hand for a few hours.
I know that Joe (Northernsledders) builds are outstanding and I am so impressed with how he lays them out for TY users but his builds are one of a kind. This Supercharger build is basically a step by step from Mountain Performance. The installation instructions are noted in the first post. I dont want to take the credit for creating the instruction I just wanted to show a few picks of how my build is coming along
Added the lines for the blow off and zip tied all the vacuum lines on the throttle bodies. Added the new new air box mount plate and reinstalled the throttle bodies back on the motor.
Mounted the oil tank for the super charger, installed oil filter and re routed the lines.
Added intake filter and pre-filter.
New Air box and blow-off valve.
Blower feed tube to air box.
Shes really coming along nice now.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
looking good. No intercooler on that kit?
Correct!! None on the low elevation, low boost MPI super charger kits.
Installed new O2 Sensor.
Radiator back on
Steering post back on
Throttle cable back on as well as the riser and bars.
Headlight and Oil cooler installed for the super charger.
Supercharger low boost pulleys and tensionor installed.
Oil tank spacers and oil tank installed.
Reinstalled the wiring and added the new gauge..
Tomorrow, top off all the fluids and give it a run.
Radiator back on
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
looking good.
Shes alive yesterday afternoon. No leaks and idled like a champ. She is ready to be buttoned up and clutched.
