fxnytrose09
I cracked an a arm and am tryout to remove my oil lites to use in the new arm. Any tricks to remove them with killing them I already started a small gouge with a hammer and punch. Thanks for any ideas in advance
livewire_101proof
I used small piece of round stock I had laying here like a punch, came in from other end of a arm and drove it from inside-out
fxnytrose09
Dr. FeeLGooD
If your A arm is nfg I would use a hacksaw to cut the end off with your bushing inside then I would cut the end open length wise. Bushing would come out very easy after that.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Like the prior comments, your only chance is to tap it out where the entire surface of the bushing is supported (cut the a arm to get at each side). If you use a long punch to work your way around the edges of it, eventually you will tear into the brass and distort its shape. They are soft like butter. I did mine this summer and by the time I got them out, they were all mutilated and unuseable.
Good luck
MS
Good luck
MS
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
find a deep well socket that is just under the inside diameter of the a-arm pivot tube and use it to lightly tap-drive the bushing out. This will support the entire circumference of the bushing as you tap-drive it out which keeps it from getting wrecked.
fxnytrose09
Got it thanks guys
- 113K
