thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Any reason not to run this oil.
Sent from my XT1564 using Tapatalk
msgt van
I believe the recommendation is to NOT use fuel economy oil. These typically have lower levels of zinc based on the charts on Mobile's website. The European car formulation has higher zinc levels.
https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide-2016.pdf
If you search the forum specific to your model you'll find tons of threads on the subject.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
FWIW - in the 16 years I've been on this forum I've read that people run run 99 cents/quart dino oil up to Shell Rotella oil for diesel engines. Has there ever been a CONFIRMED engine failure on Yamaha 4S snowmobile engines that was caused by running the wrong oil?
Sometimes I think you could pour vegetable oil in these engines and they'd be just fine! LOL!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have run the Super Tech Walmart brand in the past with no issues now that I have it super charged I don't want any extra risk. This oil is on sale at half the price so would try it if no reason not too.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I don't know why someone would spend 15k on a sled an worry about having to spent a little money on a oil change when you only do it once a year, if you had a 2 stroke think off all the cash that you spent on oil.LOL
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have close to 25K invested in my sled and I didn't have all that money by spending it foolishly oil is oil for the most part just thought I heard to stay away from this kind of oil.
energy conserving oil messes up something with the starter clutch/drive if i remember correctly. guys that ran similar oils had more starter issues at high milage vs the guys that ran straight dino oil.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
thanks for the input. Wonder why that would be there is no clutch set up on starter it is direct drive. I was hoping to see Charlie chime in on this as he seems to know his stuff on this type of thing. @Sasquatch
kingtut
When I owned my 2 stroke I used mystic oil because it had a higher breakdown Temps. Next spring will be my first oil change on my turbo 4 stroke. My 2 cents would be that if the breakdown Temps and lubrication properties match or exceed the oem oil I'd run it.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
If you check out the parts fiche you will see that there is a one way clutch on every Yamaha 4s starter drive. It is located behind your stator. This is in constant contact with the engine at all times. It has been recommended by numerous members on this site that a low friction oil is not desirable for this application. Just my 2 cents.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I see thank you so the anti-reversing clutch is affected by this oil. Is it a clutch in the gear like with an actual friction plate and disc or is it some other non friction type of clutch?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Not really a clutch. It's a one way bearing that locks the rollers when rotated in one directions and rolls freely in the other.
The problem with the Advanced Fuel Economy oils is that the Zinc and phosphorous levels are significantly low compared to the recommended oils. These additives are very important for metal to metal contact because they are absorbed into the metal and create a protective lubricating film between the surfaces. I wouldn't run any synthetic oil with levels under 1000 ppm of either additive. I've been running Mobile 1, 0w-40 which has the necessary additives with no problems.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Yamalube
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Here are two interesting and informative , if not very long, reads on engine oil. As a side note, I am not an Amsoil representative, however, Amsoil supporters will like these papers. Of course, this is a one sided perspective, but their testing results are for all to see and to draw your own conclusions.
https://ultimatesyntheticoil.com/wp-content/uploads/2016/01/G3115-OilStudy5W30Synthetics.pdf
https://ultimatesyntheticoil.com/how-to-pick-the-best-engine-oil/
PowderFalcon
Pinnin' it!
AMSOIL!
