Alpine Turbo
Hi I'm looking for a PCV map for my Yamaha Nytro turbo. I used to have rb3 installed but have remove that and I'm going to just a PCV PTI setup. I normally ride above 9000 feet and have a powder lights turbo kit with the Garrett turbo running 15 pounds of boost. I also have the injector upgrade. The reason for my swap was the rb3 box was inconsistent at different altitudes and I had to adjust my fuel pump to change the AFR when it would get too high. Let me know if you have a tuned map that might work for me as it would be appreciated.
Logan
Logan
