Allan
Just got new 2016 Phazer xtx . where are you storing you spare belt. was hoping it would fit on top of belt guard but not enough room.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Whatever you do dont put a belt in the vinyl nose bag. I am now using an 07' belt box which I think is a great piece to have. See my thread below. G.B.
http://ty4stroke.com/threads/vinyl-nose-bag-cracking-spare-belt.141581/
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
My son's Phazer has the rear box but thinking a bit about this, what about in the lower part under the clutches? A couple of zip ties to flatten the belt a bit and then a couple of small holes for another long zip tie in the lower panel to hold it in place down low. Just carry a knife (which you should) to cut the ties.
Allan
Not a lot of room down there and the speed control is there.My son's Phazer has the rear box but thinking a bit about this, what about in the lower part under the clutches? A couple of zip ties to flatten the belt a bit and then a couple of small holes for another long zip tie in the lower panel to hold it in place down low. Just carry a knife (which you should) to cut the ties.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I might be thinking about my MP. It's a little wider. I guess you just gotta try different places. Inside the clutch side cover. Inside the right side cover. Things are tight everywhere on the Phazer.
Allan
I had a MP for 2 years and put 10,000 km on it. the MP got a lot more room on the sides. Tried both sides u can hardly get your finger in the lol.
I going to carry in my my pack. I made rack for the back that can take a 5 liter can and my pack. so belt in going in pack.
kallholmen
Go turbo. When you delete air box you get more room.
Skickat från min iPhone med Tapatalk
Allan
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Mine is in my backpack which is strapped to the tunnel with bungies! Ya, I'm cheap, but the best part is that its stored in a circle shape so it doesn't take set. I've had brand new belts crack between lugs when stored all bunched up for a few years like how they are in the front A-frame bag.
