JestersYamacat
- Feb 20, 2013
- 2017 Sidewinder LTS-SE Black/ Orange, 2012 xf1100lxr Green
- Kanata, Ontario
When you get to the point it is all fabricated drop in some photos of how it works and I would most certainly be interested as I have been fighting carpel tunnel and tennis elbow issues for the last few years and lighter steering is a must.
Jester
Jester
Blueaway
I'll order it asap
Sent from my iPhone using Tapatalk Pro
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Jester
I developed tennis elbow with this sled.
Lighter steering would be great.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
What he's doing isn't electronic. I'm guessing that he's changing the geometry of the linkage where it hooks to the steering post.Any chance you could wire in something to it so that the assist level was speed activated. Under 10mph max assist. Under 20 med assist then low assist from there type of deal? Maybe have dial to raise the assist curve to higher mph ranges?
DoubleD
- Nov 30, 2015
- Portage Indiana
- 2017 Sidewinder STX DX 137
2007 Attak
- GOOGLEPLUS
- dlambert1998
Interested as well.
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
Travis, will you make a kit for the Nytro as well?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Here is his prototype. Should be easier to steer.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
You must be on slederz!Here is his prototype. Should be easier to steer. View attachment 128337
Sent from my SM-T705W using Tapatalk
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Nah I just googled a snowmobile with wheels. Can't wait to see what Travis comes up with.You must be on slederz!
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I understand that. But could find a box to do that. Might even be able to use vaccume pressure to do it. Just an idea for something he could play withWhat he's doing isn't electronic. I'm guessing that he's changing the geometry of the linkage where it hooks to the steering post.
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
I'm baffled as to how this is going to work. But excited to see it! How can you get lighter steering without some sort of electric or hydraulic assist, or changing the ratio... which wouldn't work with handle bars that can only turn so far.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
You are correct...handlebars can only turn so far. When trail riding however you almost never utilize the full range of motion of handlebars. Other than parking lots you really don't cycle bars from stop to stop. I specifically wanted to be sure I trail tested the concept to be sure taking away from turning radius wasn't detrimental. In 110 miles of trail...some very tight and twisty I never had bars turned against stops unable to turn sharp enough.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I just noticed you are testing with Curves .So....if I can design a product that will make the Sidewinder feel like it has power steering how much interest is there??
I finished up a prototype yesterday and have started testing it. I'm testing it with curve skis....and steering effort is a breeze! I've developed a lot of products for yamaha sleds, and I'm really excited about this one. I think it could be the game changer that pulls my father away from his EPS apex. He's going to ride it tonight and see what he things! Will update after more testing!
As only some feel the Curves steer hard , and a lot think the Tuners steer hard , wouldn't a truer indicator be if you tested with Tuners on ?
hardfacer
- Feb 15, 2006
- Myerstown PA
- 2017 Siewinder S-TX,(Barn of Parts upgrades) "MPS" Kit, 4th wheel kit, Yamaha Throttle kit, Ignition Relocate, Hose protectors, Driveshaft expander and Curve Skis
- Myerstown PA
Was in NY testing this with Travis the other week. I always liked the power of my 2011 Apex with power steering. The difference Travis's prototype power steering Mod has over the stock setup is truly remarkable. With his new product I would now consider giving up my EPS Apex for a Sidewinder or (Viper). And if you already made the switch from an EPS to the Sidewinder I think this something to consider. "Because you can't explain the benefits of EPS on a snowmobile to someone that does not have it "(especially after a long day on the trails).
allyammies
So when is the pre order! Think I'm in.
- 8K
