customnytromtx69
hey guys,
Anyone have a wiring diagram for the ignitions for the winders? I'm looking at putting together push button start kits just want to use my MTX as the test mule as she is down waiting for new tunnel to show! I'm trying to source good waterproof push bottons or a toggle switch and start putting these kits together !
Just wondering if there is any interest in these and if you guys have any suggestions on what you'd like to see ?
Winder Manual has a unreadable wiring diagram once again. Same as Vipers. Will try to get the Cat version in next few days. Thiers is always legible.hey guys,
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
I've used Mouser.com in the past. Wide variety of switches, contacts, wiring, relays, assemblies, etc. Decent pricing too. They also have PEOPLE you can talk to.hey guys,
Also, I'd be interested in a reasonable setup too. Maybe two.
Thanks!
customnytromtx69
Thanks for the info , I'll take the multimeter out and figure it out the old fashioned way LOL
Thanks!
Thanks for the link ! I'm debating between a dash mounted push button led lit switch or a handle bar mounted , personally I would rather the dash for the fact it's not goin to get hit rolling the sled over or by accident but just feeling out what people would want
Design a kill switch like the ignition switch.
Down= ign off
Up one click=ign on
Pull up(no detent)= starter
Would be a very clean design.
Down= ign off
Up one click=ign on
With a flip up cover like the Planes have! Bling.Design a kill switch like the ignition switch.
Down= ign off
Up one click=ign on
http://www.ceshowroom.com/ProductDetails.asp?ProductCode=PETWIR20565&click=2
http://www.ebay.com/itm/Aircraft-To...le-/140432935972?_trksid=p2141725.m3641.l6368
PM me for 2016 wiring diagrams. Should be same for ignition switch at least. Its normally closed system.
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Does this help you?
customnytromtx69
Down= ign off
Up one click=ign on
Yes it would be !! Will take some time to source a QUALITY switch configured to do the job, I am looking for ip67/ip68 minimum right now, then soldered and heat shrunk terminals as well as PET wire loomed pig tails
Does this help you?
Yes it does massively thank you
RAMSOMAIR
Would prefer a standard push button switch that returns to zero when released.
customnytromtx69
This is what I'm looking at doing for right now, something flush mounted , big enough to push with gloves , waterproof and led lit for night ridesWould prefer a standard push button switch that returns to zero when released.
Pstn head
A switch like Steiner mentions so that we can prime the fuel before starting would be nice
AXR
- May 5, 2007
- Central NY
Flipping you kill switch back on would reprime the pump.
You guys are still priming your sleds? Do you prime your car? I just get in or on and turn the key. If it doesn't start must be something wrong.
AXR
- May 5, 2007
- Central NY
I agree letting the pump cycle makes it start harder after the first start of the day.You guys are still priming your sleds? Do you prime your car? I just get in or on and turn the key. If it doesn't start must be something wrong.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyone get one installed. Was thinking of using the rsi rer billet button ....or using the skidoo xm rer block and brake combo ...wire in the rer button for start and the dimmer ...then move the hand warmers to the dash. Since I'm running a mtx ...planning cfr risers and boondocker handlebars ....would really like to clean the bars up. Then planning different throttle block , reverse button and kill switch. I always wear a tether so not worried about the push button sticking if I roll. Thoughts?
