porkhaaks
- Feb 23, 2010
Has anyone had a problem with an oil leak from the stainless steel oil line, on the drivers side, at the rear of the ENGINE????? This line has two bolts going through it with one washer on each side of the fitting where the bolts go through the LINE ... I have replaced the line once already.
did you check the washers for damage when you replaced the line? might just need new copper washers and a good cleaning with brake clean.
porkhaaks
- Feb 23, 2010
The line that WAS replaced was leaking at the top fitting AGAIN. At the fitting, the washers were all good. DAM do not know why, that is my second line !!!!!!!!!
ouch. i would be tring aftermarket one that is more flexable in your case. that sucks dude.
