novis
Hi all, and sorry for my English
I want a lower gear ratio on our RS Viking -06 , it is possible to change gears?
Joner
I had an 06 and the no low range was terrible. Try putting more preload on the secondary using the 6 and 1 holes on the helix instead of the stock 3 3. This will squeeze the belt more get the rpm up and hold the low gear longer. You could drop a tooth in the top gear from 18 to 17 without changing the chain but I would try the helix first.Hi all, and sorry for my English
