BigDogrx1
Guys keep the real Daddy of the 4strokes strong, what are you doing to yours for next winter?
Mine so far:
Mono Skid: last year
2" pivot riser: last year
seat: last year
Handlebar hooks: last year
New grips: last year
Windshield cut down: last year
This summer:
Paint exhaust tips: done
Repair exhaust: done
13mm sway bar: done
Clutch kit: ? Not sure
Red snow flap: ordered
Coolant temp gauge: done
Mine so far:
seat: last year
This summer:
13mm sway bar: done
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Larry said it before love that sled looks great
BigDogrx1
Thanks TomBob.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
All maintenance on mine this year-did get the 13mm bar thought
jong22250
Stearing stem relocation and skinz air frame seat then iam done with it only other thing I did this year was phazer running boards wich where a huge improvement for my big #*$&@ feet
superfan75
Last year I did quite a bit to mine. I did a suspension swap to a Ski Doo Grand Touring skid for a good 2 up ride and it worked out really well. Then I did the Apex radiator install. I also changed the front end bushings to the Ulmer oilite bushings and also some ball joints. Then a 2" riser, Mountain RX throttle cable, Powermadd PSG1 hand guards, GPS mount, and Simmons Flexi skis. Before this winter I want to change the rest of the ball joints, upgrade the steering blocks to OFT steering blocks, new exhaust donuts, new center skid shock, and carbides. Then for the really fun project I want to change all the drive bearings. Also of course every year an oil change.
Nielv
- Nov 30, 2014
- 2004 RX1
What temp gauge did you use? Thanks
BigDogrx1
Temp gauge is autometer, electric
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
Larry temp gauge looks great. I added mine do to over heating just keep eye on it. Finally had to add rear heat exchange, run at 170 deg now
Ratpack
Last year, everything was fixed or replaced. This year, mine is finally getting a head shim.
BigDogrx1
Ya,
Thanks Tom, mine has rear exchanger and runs #170 alsoLarry temp gauge looks great. I added mine do to over heating just keep eye on it. Finally had to add rear heat exchange, run at 170 deg now
BigDogrx1
Just dropped off both clutches to Schmidt Bros Performance, Chris will Wright a small prescription for Steroids for both, that will be it this year, love that 0-60 pull, he says it will be 4 sled length gain
BigDogrx1
Ok boys started fabricating a new frt tube bumper today, will post pic after its done, 1 1/2"
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
What is the history of RX-I know it was first four stroke
dudester48
- Jan 30, 2015
- warrior
whats this steering stem relocate. anybody know how this works.
