- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Here is a list of all the torque specs for the RX sleds.
Overview Sheets
Engine 1,Engine 2
Power train 1,Power Train 2
Chassis
General Torque Specs
Chassis:
Front Suspension
Handle Bars RX10 RX10S RX10R RX10RS
Handle Bars RX10M RX10MS
Steering Links
Ski
Power Train
Primary Clutch Bolt
Primary Clutch Exploded
Secondary Clutch Bolt
Secondary Clutch Exploded
Chaincase Without Reverse
Chaincase With Reverse
Driveshaft
Secondary Shaft
Brake Caliper
Brake Caliper and Parking Brake
Master Cylinder
Slide rail Suspension (RX10 RX10S RX10R RX10RS)
Slide Rail Suspension (RX10M RX10MS)
Engine
Seat and Fuel Tank
Exhaust Pipe and Muffler
Exhaust Pipe Mounting Bolts
Flex Pipe Clamps
Engine Mounts
Cylinder Head Cover (Spark Plugs)
Cylinder Head
Oil Pan and Pump
Valves and Valve Springs
Crankcase
Crankshaft and Counter shaft
Connecting Rods and Pistons
Camshafts
A.C. Magneto and Starter Clutch Cover
Carburator
Cooling
Heat Exchanger
Water Pump
Thermostat
Electrical
Starter Motor
If I have missed anything please let me know!
Overview Sheets
Engine 1,Engine 2
Chassis
Chassis:
Front Suspension
Steering Links
Ski
Power Train
Primary Clutch Bolt
Driveshaft
Secondary Shaft
Brake Caliper
Master Cylinder
Engine
Seat and Fuel Tank
Flex Pipe Clamps
Engine Mounts
Cylinder Head
Oil Pan and Pump
Crankcase
Camshafts
Carburator
Cooling
Heat Exchanger
Water Pump
Thermostat
Electrical
Starter Motor
- Nov 1, 2009
- 2009 Phazer RTX
Also if any of the links do not work let me know as well.
Sled Dog
Good job bud the handle bar one is not working for me anyhow.
- Nov 1, 2009
- 2009 Phazer RTX
Sled Dog said:Good job bud the handle bar one is not working for me anyhow.
Fixed it!
mongaupt
I'm little lost on the primary clutch bolt.
1st torque down to 85 pounds. Then loosen it and torque down to 43 pounds.
Am I reading this correct.
yes that is proper procedure. 1st torque seats it on the taper. 2nd torque is just to keep it there.
