jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Anyone seeing this code. Had it a few times now on hard pulls. I know stockers we're seeing this code at times. Thanks for any info
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
saw it once today...but only right after the charge tube blew off the turbo! It almost threw me over handle bars it cut power so fast. At first I thought I blew a belt...but nope...blew that hose right off...and couldn't find the clamp anywhere. Had to steal a clamp of intake and swap it over. I then tie strapped the intake tube on.....wasn't that pretty..but needed to make it home. Anyways..after i got it all fixed up trailside code 26 came on. I shut down sled and restarted...came back on immediately. I drove with it on for about 2 miles, it went away and didn't come back.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay thanks. Have to check that clamp tomorrow am before ride. I have seen it a few times in 500 miles. Today 2 times.
1100saber
- Dec 17, 2016
- northern ontario
most likely that charge tube is not sealing properly....that would be about the highest point of boost...and the hottest being right beside turbo...When i reinstalled that charge tube...felt so flimsy because of the heat it was exposed to.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thank you. I will check mine AGAIN tomorrow am. Will report back. It has to be a Slight leak as mine is not throwing code alotmost likely that charge tube is not sealing properly....that would be about the highest point of boost...and the hottest being right beside turbo...When i reinstalled that charge tube...felt so flimsy because of the heat it was exposed to.
Snake
- Mar 3, 2016
- Maine
- 2017 Sidewinder XTX 137 LE
Search function works great
http://ty4stroke.com/search/622655/?q=code+26&t=post&o=relevance&g=1&c[node]=119
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
That's why I never leave home without long #*$&@ zip ties,they do come in handy from time to time,glad the code cleared its self.saw it once today...but only right after the charge tube blew off the turbo! It almost threw me over handle bars it cut power so fast. At first I thought I blew a belt...but nope...blew that hose right off...and couldn't find the clamp anywhere. Had to steal a clamp of intake and swap it over. I then tie strapped the intake tube on.....wasn't that pretty..but needed to make it home. Anyways..after i got it all fixed up trailside code 26 came on. I shut down sled and restarted...came back on immediately. I drove with it on for about 2 miles, it went away and didn't come back.
johnnysnowking
I just got a sd48
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
I got a code 30 after I tipped on its right side so I could adjust the skid springs flipped it back over it wouldn't start no display, no nothing let it sit for five minutes play with the switches and kill switch and it all came back but then I got a code 30.
Sent from my iPhone using Tapatalk Pro
