TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
The last 3 years I have been using seafoam start of season then last run, also stored with it.
One ounce per gallon. Took the carb's off just to check them, Totally spotless clean as whsile,
looked like they were just cleaned.
Did find the o-ring on the main jets and float bowls gaskets need to be replaced. Think might use less then
ounce per gallon.
Course broke one of the heater lead wire off. Do not know how to fix that.
Changed screw on bowls to hex head 4mmx12mm
ounce per gallon.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Thanks for your report on the Seafoam....good info. The info on changing those pesky Phillips head float bowl screws to hex head is also a good idea.
BigDogrx1
Ya Tom I use it on sled,tractor,saws, anything uses gas and all my stuff always starts and runs well even seasonal stuff.
My carbs where clean as new also, only reason I took carbs apart was to re-jet.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I sell Seafoam. Have been using it for years. I would buy it by the gallon for using in my bass boat (Yamaha ProV150) with EVERY tank of fuel. In my boat I would use about half a can per 20-30 gallons of fuel.
I put seafoam in everything. You don't have to worry about using too much. It won't hurt anything.
I use it for storage too, and my gas smells fresh as it can be after sitting during off-season, be it my snowblower, sled, lawnmower, etc...FRESH and clean.
I would drink it if I could.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Lol
87gtNOS
- Nov 30, 2005
- Toronto
let me add, on my ex's ZR900, I would put it in every tank of fuel (my apex every 2nd or 3rd tank I'd splash some in) as the sleds are garage kept. I would also put a splash in her tank almost everytime we headed out (taking the sled out of the heated garage).
I do the same with my current g/f's SRV.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
How do you keep finding girls who ride?
I'm an avid Seafoam user as well. Never thought it might help me run better though. Hehe
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
If I knew seafoam helps with that, I would have started using it years ago...How do you keep finding girls who ride?
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Sorry Gents......this is getting a little!!!
Douglass
- Jan 17, 2016
- Portland
- 2012 Apex xtx
2006 attack
2000 mxz 700
1996 polaris indy ultra sp 680 small mods.150 hp
mix it light... otherwise it will eat them rubber parts...I sell Seafoam. Have been using it for years. I would buy it by the gallon for using in my bass boat (Yamaha ProV150) with EVERY tank of fuel. In my boat I would use about half a can per 20-30 gallons of fuel.
87gtNOS
- Nov 30, 2005
- Toronto
Seafoam will NOT harm rubber.
Ethanol does.
Ethanol does.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
I am going to put rubber grommet in small disk add seafoam see if effects it. Tomorrow then will know
