secondary coil bind/pocket depth
Is it safe to say by adding a 1/16" helix shim will bring your belt 1/16" deeper into secondary at full shift? I have very minimal paint removed from secondary spring, looks to be a slight amount of coil bind, however I can see how far the belt has travelled to the bottom of the secondary and I'm very close to the hub with no shims. I'd like to eliminate this coil bind but I don't want belt to bottom out on secondary hub and blow a belt? On a side note I'm at 250 miles, original 8jp belt, primary clutch kit, cat rollers......just wondering if I should shim or not........
You should be able to test with your secondary assembled without the spring. See how close your belt is to bottoming out at full shift.
