jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What's everyone going to run for clutch weights in this beast? Stick with the stock? Also the stock are adjustable? With different rivets I believe.
- Apr 14, 2003
- Hessel, Michigan
I will run stock for a couple weeks, then will be putting in Thunder Products adjustable weights.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
One needs to be careful when selecting aftermarket adjustable weights since not all profile curvatures are same as stock. Not always a bad thing but can throw you off sometimes.
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
- Viper, Apex, Sidewinder
I wonder if the thunder big venom kit weights on my sr viper would do the job on my SW? I know I can use them on a turbo viper,
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
You need more weight , the Viper NA weights are way too low for ANY turbo sledI wonder if the thunder big venom kit weights on my sr viper would do the job on my SW? I know I can use them on a turbo viper,
