Here:
Viper and Sidewinder Guage Operation Videos
https://ty4stroke.com/threads/guage-operation-videos.147610/#post-1355769
*Important*
Sidewinder TPS reading is in Degrees and Viper is in % so when setting throttle freeplay take note since Viper will near 100% and Sidewinder 80 Deg. at full throttle.
*Important*
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Spoke too soon on the other thread. This is sweet. I love the diagnostic mode on the nytros. Looks like we have it back now.
Yes it's a nice guage. Only thing I see missing vs Nytro,Phazer,Apex is the CO adjustment. I bet there is a way but haven't figured it out yet.Spoke too soon on the other thread. This is sweet. I love the diagnostic mode on the nytros. Looks like we have it back now.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Can we read A/F and turbo presure in the display ?
No AF since no O2 sensor but Boost should be available via the Map sensor. There is a formula you would have to use since it will show total I believe. Once I get my Viper together plan to make a guage operation video. Is more on the Sidewinder but majority is same. You get into diagnostic mode by holding the left and right bottom buttons down at same time then scroll through screen. This is off top of my head though. I invite someone to play with it and make a video. Would really be nice and just have not got around to it past few years as promised. Always is best if a nice looking woman with pretty voice does the vid. Thats definitly not me!Can we read A/F and turbo presure in the display ?
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
It would have been sweet if we could read A/F and boost pressure on the Sidewinder with the display. Sould be factory since it is a factory turbo so we dont have to by a A/F and boost gauge.
You can read Boost just have to do the math. I agree though. Not sure why they dont have it on in a prominent area. Maybe to discourage modding? Is some pretty smart people out there. I am sure its just a matter of time before someone hacks the guage and allows all those options and more. You guys do know there is a MAX rpm function right?
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Max rpm function?? No what is that?
Everytime you shut the sled off its reset.What you do is whatever window you have rpm shown in"You can move it" You push the button next to rpm and hold it. That will show you the Max rpm and is accurate since guage reads slow as visible on readout. Max is accurate.
Max works great for clutching accurately.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
How do you get screen into diagnostic mode ?
Push left and right lower buttons down at same time then hold. All this is better explained with a video. Long overdue.
Just tried it.
With key on press left and right bottom buttons on guage. This puts you in diagnostic mode
Using right side buttons scroll till map sensor is reached. Press button by select you now have map reading
Start sled read reading. I believe holding button by reading will give you max reading. Didn't check
That number will have to be converted to PSI after subtracting current baro you can use this converter.
http://www.calculator.org/property.aspx?name=pressure
Using a calculator or pen and paper
Convert MAP kPa to psig (gauge): MAP kPa x .145 − 14.5 (slightly above sea level) = PSIG
Lots of other thing in that mode also. No AFR though.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Wow,you the man cannondale27 nice find,and thanks for the conversion.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
CRAP! Now i need to bring a calculator. I just figured out the clock...
- 48K
- 36K
