DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Did you notice any difference in how the Dalton helix contacted the rollers?35/39
Shagman's helix from Dalton
- Apr 14, 2003
- Hessel, Michigan
Everything good so far. Will there be a roller that will not have contact? I am betting so...but I wouldn't be worried about it.
Bad part...the rollers are a moveable item where the pucks were not. You may not realize this...but the helix on the older button clutches did not make contact on all of them either. Wear was different from puck to puck, but the moveable roller makes everyone freak out.
dsimonRX1
I remember this as well. The tolerances across the board would have to be extremely tight to ensure all 3 touched.
Jafo1970
I have a stm 38 helix on now and only one roller touches. My stock helix had 2 touching at least.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I guess it's not the helix lol
dsimonRX1
Sorry about that, this was on my Sidewinder which has EVO stage 4 flash.
But, my turbo Viper was also in the 126mph range....but top speed was the Sidewinder
What 141" track are you running?
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
I have a dalton helix and cat rollers. All rollers are touching. 350 miles on the new rollers and helix. Everything looks good
Scottyvodka
Stock helix with cat rollers, all 3 touching. Guess I'm lucky.I have a dalton helix and cat rollers. All rollers are touching. 350 miles on the new rollers and helix. Everything looks good
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I thought I read earlier but can't find it now - do the Dalton helixes have a slightly deeper pocket than stock? Meaning, will one of these negate the need for me to have the stock pocket machined deeper to avoid coil bind?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What do you have yours wound at? 3/3 or 6/1 ?Stock helix with cat rollers, all 3 touching. Guess I'm lucky.
Scottyvodka
Set to 6/1.What do you have yours wound at? 3/3 or 6/1 ?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks.. Not sure it makes a huge difference but on mine 6/1 tightened up my rollers on helix.. seems to increase backshift though.Set to 6/1.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Terry, can you post your rpms, from initial flash to top speed, with the reverse helix (33/39??) please.
Traditionally with 4s torque we want to flash lower on torque and build rpms on top speed, but it seems by your posts the turbo likes to drop down rpms on top end to build more speed? Just want to understand your setup bud.
thnx
thnx
- Apr 14, 2003
- Hessel, Michigan
Stock 1.6 Cobra 141
- Apr 14, 2003
- Hessel, Michigan
thnx
Stock helix - my run would be 8,900 - 9,000 -9,100 - 9,100 - 9,000 - and finish off at 8,9XX
Reverse angle - 9,200 - 9,200 - 9,100 - 9,000 - 8,900 - and finish at 8,8XX
This is why the sled will stand up so easy, because of the reverse angle helix
