1. PLEASE READ: If you have problems logging in with your old password, click the Forgot Password link in the log in screen to get an email verification to request a new password or click Here. If you haven't received a new password from the forum please email your username and password to webmaster@totallyamaha.com. Sorry for the inconvenience.
    Dismiss Notice
  2. All hotmail, msn, outlook, live email accounts are not receiving email notifications. The only way to remedy this is to add @totallyamaha.com to your safe senders list in order to receive notifications.
    Dismiss Notice
Sidewinders on asphalt April 23rd, Mid Michigan Motorplex
Discussion in 'SideWinder Trail Talk' started by NOS-PRO, Apr 26, 2017.
  1. NOS-PRO
    NOS-PRO "The Burnman" Vendor VIP Member
    5,893
    Newton, Wisconsin
    Country:
    Snowmobile:
    Sidewinder, SR Viper, Nytro, SRX, Phazer, V-max 4, SX-R
    Shagman, myself and another (just keeping his name secret in case he didn't want it posted) went to Mid Michigan Motorplex for the MSADRA snowmobile race, #1 of 5 races scheduled.
    3 winders
    Shagman - Aftermarket suspension, 136 track, thunder clutching, 23/38 gearing, EVO stage 3 and EVO exhaust
    High 9's/low 10's spinning the track in the 1/4 mile. 1/8th mile times were not too bad....but lots of improvement left.
    My winder - stock suspension lowered, 136 track, thunder and OSP clutching, 22/40 gearing, EVO stage 4 and EVO exhaust. High 9's/low 10's not spinning, but had my clutching so low that it took forever for the sled to build boost. 1/4 mile speeds close to 128mph. Lots of improvement left.
    Other winder - Aftermarket suspension, 136 track, special clutching, 21/41 gearing (stock), EVO stage 4 and aftermarket exhaust. His 1/8th mile times were just as quick as my SRX set up for asphalt and was 5.9's which comes out to be very low 9's in the quarter mile. No spin and was great to see the potential these winders have. He would have run the winder the full 1/4, but ran out of gear.
    We are having fun with these winders and will get these all dialed in to run low 9's consistently :)
    What's cool is 3 sleds and we can judge by each others sled what works and what doesn't.
  2.
  3. Dieselxtx
    Dieselxtx Expert
    263
    Fox Lake, WI
    Country:
    Snowmobile:
    2017 Sidewinder BTX LE
    2012 Nytro XTX 1.75
    What helix did you try that it wouldn't spool up quick enough?
  4. Doowithblue
    Doowithblue VIP Member VIP Member
    276
    Waterloo ON
    Country:
    Canada
    Snowmobile:
    07 Mach z x (sold)
    17 Ltx-le
    82 SS440
    What's the special clutching in the 3rd one?
    slowride06er likes this.
  5. sxr70001
    sxr70001 TY 4 Stroke Junkie
    625
    Michigan
    Country:
    Snowmobile:
    SR Viper RTX SE
    SXR 700
    I live in mid Michigan if you guy race there again let us know. I will try and make it to watch. Nice Job as usual!
    NOS-PRO likes this.
  6. Snowaddict
    Snowaddict TY 4 Stroke Guru
    901
    Menasha, WI
    Sounds like a good start to the season. Lots to look forward to. When does the WIR season start?
  7. NOS-PRO
    5,893
    Newton, Wisconsin
    Country:
    Snowmobile:
    I tried the 33/35 which should have spooled up fast....but believe the warmer weather plays a factor, plus the very low engagement needs to be played with.
    DIALIN43 likes this.
  8. NOS-PRO
    5,893
    Newton, Wisconsin
    Country:
    Snowmobile:
    Race on May 13th at Mid-Michigan Motorplex.
    Thanks bud!
    DIALIN43 and sxr70001 like this.
  9. NOS-PRO
    5,893
    Newton, Wisconsin
    Country:
    Snowmobile:
    WIR started last weekend. But I am not racing the points series there. I might go and watch or even make a run....but running the points races in Michigan. Payout so much more and better conditions.
  10. shagman
    shagman Lifetime Member Vendor Lifetime VIP Member VIP Member
    884
    Cedarville Michigan
    Country:
    Snowmobile:
    2014 SR Viper XTX SE (Sold)
    Gearing correction 26/48 in my sled. I ran between 6.20 and 6.25 in the 1/8 mile @ 114-116 mph. only ran a couple passes of full 1/4 mile 9.98-10.05 @ 126-129 mph. Like Nos said I was spinning some but have made changes to fix that problem. Thunder primary clutching and 35 deg stock helix.
  11. krm
    krm Expert
    415
    ny
    Country:
    Snowmobile:
    sidewinder 850 mxz,800 xrs
    Try the 33/35 ,it WILLrev faster .
  12. shagman
    884
    Cedarville Michigan
    Country:
    Snowmobile:
    I'm not having rpm issues. Mine is actually spinning off the line. That is why I haven't went to the 33/35 yet. Going to taller gears and some suspension changes should fix that. Then I will try 33/35. I know Terry's bogged off the line but he only had time to run it once or twice. I think it was just a fluke thing. He needs a test session with it. I've run mine twice now and it's getting better every time. Just need time to test. You can't test and make changes when bracket racing because of dial in times.
  13. Dieselxtx
    Dieselxtx Expert
    263
    Fox Lake, WI
    Country:
    Snowmobile:
    2012 Nytro XTX 1.75
    I finally got my sled back from the dealer today after a month of waiting I'll be getting my asphalt setup installed tomorrow may 13 isn't gonna work but I'm hoping to make the June race in MI
    shagman likes this.
  14. snowbeast
    snowbeast TY 4 Stroke God
    3,911
    E waterboro,maine
    Country:
    Snowmobile:
    2015 apex xtx traded for a 2017 sidewinder L-tx-le
    FACEBOOK:
    yes
    YOUTUBE:
    yes
    what rpms are you running with evo 3 tune? if its 9000 or better,that gearing should net you 129-132 at 9000,and that's getting it done. I am surprised you guys are out of gear in less than 1/4 mile with stock 21/41 you guys are not getting any O.D. with stock gears? At any rate,sounds like you three are off to a very good start,and all three are running stock skids,with just a standard asphalt track?
  15. shagman
    884
    Cedarville Michigan
    Country:
    Snowmobile:
    Running 8900-9000 rpm. 10 tooth 2.52 drivers which is 115 mph without overdrive. I'm at 129 mph in 1/4. 14 mph overdrive is pretty good. I'm running an aftermarket skid. Pro Stock Inc. next gearset going in is 27/43. Hope to pull 135-140 mph in 1/4.
    DIALIN43 and slowride06er like this.
  16. Dieselxtx
    Dieselxtx Expert
    263
    Fox Lake, WI
    Country:
    Snowmobile:
    2012 Nytro XTX 1.75
    Sled is ready for testing running 24/38 gearing and waiting for Lon at Thunderproducts to get more clutch kits in stock!
Share This Page
