obr
1CS: the difference will be the gearing. Bigger number = higher gear.
Phazer: they are 2.52.
phazerboost
I was wondering if you can get the doo drivers in 2.52 pitch?
obr
Correct me if I'm wrong, but the doo drivers described here, are all 2.52 pitch.
n2oiroc
you need the 9 tooth. btw the 8 tooth are 3" pitch and will not work!1CrazySledder said:Okay, which ones do I get? I have a 2006 RTX that I will be putting a 136" suspension on it and a Turbo next season. What would be the differances from 8 tooth, 9 or 10? Thanks.
Vince
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi powerhaulic are you selling these drivers,or will any doo shop have them in stock?POWERHAULIC said:The numbers are as follows.......
All drivers are white internal/external, and very good quality.
9 tooth #504152503
10 tooth #504152502
n2oiroc
any doo dealer can get them they are $49.99 each.mnmsnowbeast said:Hi powerhaulic are you selling these drivers,or will any doo shop have them in stock?POWERHAULIC said:The numbers are as follows.......
9 tooth #504152503
10 tooth #504152502
BETHEVIPER
at 50$ wahl bros. must be pissed.
n2oiroc
BETHEVIPER said:at 50$ wahl bros. must be pissed.
and the doo drivers are a better piece too. double whammy!
justinator
n2oiroc said:i just bought a set of the 9 tooth and they look like nice pieces. do the milled out spots on the drive lugs go on the inside or outside?
the milled out section goes towards the outside, they are there for the track clips.
number1kyster
Just an update: Skidoo no longer sells these drivers individually! You can only buy them on a shaft and it cost 300 bucks!
ahurl90
you can still buy them at tracksusa.com
BETHEVIPER
i just ordered them at my dealer, 53$ each. they said the computer said there is over 200 available. 10 tooth ones at least.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Okay I've been following this thread and since I'm putting a new track on and changing all the bearings I might as well throw a set of these on as well...What do I need for an 05 vector...the 9 tooth #504152503 ????? The track is a 2.52 pitch cobra fully clipped 9052..Was looking to gear down a little..
Puppe
Just got BRP 9 tooth and going to install to Nytro.
Also bought IQR race sleds 121" 1.75" track, friend says it has great lifetime.
Does anyone have installing measurements for a Nytro drive axle?
