wacnstac
Now that I have some miles on my Slydogs, I concur with the opinions of most here that they dart a lot. After dropping that money on the skis and the mount modifications to get them on, I'm not about to abandon them. I notice the darting is worse when my wife is on the back of the sled.
Are there some dual carbides that will work with these skis? I am running 6" singles now. Would 3" be the right size for dualies?
wacnstac
Actually it looks like Accord now has something that might work if Slydog = C&A Pro
http://www.snowstuds.com/aftermarket_dd.html
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I've been running 7" Powder hounds for 2 years and they are a great ski ! I have Snow trackers on them now and they Rail. If you don't want to spring for the Trackers some Slim Jim"s with a shim in the back of the ski rubber works awesome, Before the Trackers I ran Bergstrum Triple points with a shim on the rubber worked great. First thing I would check is the ski Alignment make sure they are towed out about 1/4" to 3/8"
wacnstac
I'm toed out at about 3/8". Might try the Accord doubles if they are just bolt on.
DGZRT
- Feb 23, 2006
Have you shimmed the ski rubbers? Slydog used the same bolt pattern as the C&A ski'sI'm toed out at about 3/8". Might try the Accord doubles if they are just bolt on.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I had Slydogs and I also have the Double Downs on another pair of skis (Camoplast All-Terrain) that I'm currently running with and I can tell you that the DD will not fit on the Dogs even if you find a set with the same mounting stud configuration. They are just too wide for the Dogs and their skinny keels. That's why Accord doesn't list the Dogs. Only ones I could see to fit on the Dogs are Bergstroms and possibly Woody's Slim Jims.
wacnstac
Hmm, glad I checked here first before I bought.I had Slydogs and I also have the Double Downs on another pair of skis (Camoplast All-Terrain) that I'm currently running with and I can tell you that the DD will not fit on the Dogs even if you find a set with the same mounting stud configuration. They are just too wide for the Dogs and their skinny keels. That's why Accord doesn't list the Dogs. Only ones I could see to fit on the Dogs are Bergstroms and possibly Woody's Slim Jims.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
One way to be sure if to contact Accord. I loved the Dogs but the darting was just too much for me.
wacnstac
I just contacted Accord and they did say they would work with Slydogs. Also found this http://www.ebay.com/itm/6-034-Snows...e-XS-Slydog-skis-C-amp-A-CA-Pro-/311057915154
The only reason I haven't ordered them yet is your comments Moose. Did you actually put them on your Slydog skis? Do they stick out from both sides of the keel?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
No, just by observation of the size of the DD and the size of the Dogs' keel, it would stick out on each side. Don't know what kind of effect that could have. Might make it steer better by scooping more snow? On my All-Terrains, they are the full width of the keel. Not at home right now so I can't do any measurements.
wacnstac
So you still have the SlyDog skis? If so I'd really appreciate a measurement if you could do so when you get home.
DGZRT
- Feb 23, 2006
I can tell you my Snowtrackers stick out from the edge of the keel on both sides and no Ill effect yet!
wacnstac
Actually, I think I found my answer here: http://ty4stroke.com/threads/snow-studs-double-down-carbides-for-slydog-skis-review.97661/
DGZRT
- Feb 23, 2006
DGZRT
- Feb 23, 2006
- 11K
