Alright so have read all the bad and good about snowtrackers and have decided I'm going to give em a shot.
Looked on their site for the appropriate part number and I'm a bit confused. There are different part numbers for a 2003-2005 rage and 2006-2007 rage. Yamaha did not make a rage until 2005 and I thought all year Rages had the same skis so I am confused as to which part number I need. Anybody know anything about this? Also I am undecided if I should get the agressive or semi agressive. I am picked with 108 but am pretty ingnorant when it come to skid setup so I was thinking semi's which should just require zero toe and taking pressure off the skis which I can handle. Thoughts?
________________________
If you are pic'd then I would go with the Aggressives.
Look where it says All 4s ex below ......................... 06-15
http://www.royaldistributing.com/Catalogues/Main/2017-Fall-Winter/#263/z
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
X2 aggressives. As they wear they will become semi-aggressives.
Thanks Steiner but am still a bit confused. Looks like aggressive it is but I have and 05 rage so based on this sheet I would need the 08-19414. While 06 and up would need 08-19412. Wasn't aware of any major difference in ski between the years. Tried to email snowtracker but email bounced back underliverable. I can get a super deal on the 08-19414 just want to make sure they are correct for my sled.If you are pic'd then I would go with the Aggressives.
Yep, going to call tomorrow
Indy
call Travis at Barn of parts .com
Got it figure out. 19414 is for skis with aluminum saddles. 19412 is for saddleless skis
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Rage ski had a deeper keel so studs are longer. The aluminum saddle ski also required longer studs so that's why they share same part number.
I was told by snowtracker that the aluminum saddle ski has a slightly different profile. Carbides are essentially the same but the curvature of the dual runner portion is slightly different
Ok, so got some agressives. I know they require zero toe. Instructions say remove ski pressure with front shocks and skid for the agressive.
I have read some post on here saying zero toe and remove ski pressure with front shocks only no rear skid adjustment even with agressives.
Any thoughts or feedback from anyone with first hand experience?
