**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if you look at the center of the tunnel you will see a wire mold...as you will see....there is a rear heat exchanger protection kit necessary and it includes a center piece...however there are no tunnel protectors in the center...
now its fairly unlikely to hit the mold...however, studding "up the middle" or "center belt" only will enhance the possibility of hitting the mold...
therefore, I am recommending you stay out of the center 1.5" of the track .
its never a great idea to stud in the center 1" anyways if it can be helped
orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
What about adding the AC tunnel protectors that come as a set of 3 to protect the middle? I just got some but haven't installed them yet. Would that be enough protection?if you look at the center of the tunnel you will see a wire mold...as you will see....there is a rear heat exchanger protection kit necessary and it includes a center piece...however there are no tunnel protectors in the center...
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
that protects the rear heat exchanger...there is nothing forward of that to protect the center of the tunnel
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Any chance e of a pic? Mold?
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
didn't the viper have molding up the middle also for the taillight wire?
krm
- Apr 22, 2016
- ny
just look if you have one .you can't miss it .no reason to stud in the middle of any track .this has been the case after there being no more cleated tracks .Any chance e of a pic? Mold?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Good catch , Going to be interesting for guys running ALOT of studs if the middle 1.5 inches is off limits.
I studded and have a few that are close. not to worried, got 168 in to start. not super aggressive on length
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
actually even I missed how bad it could be...look up forward ...see that louvered tunnel area ...drops down what 1/2" take that away from the tunnel protectors 1" protection...guessing at 1/2" max over the lug..far less than 12-16 procross sleds...still checking
franklin
Viper had same mold up the center never had a problem with them
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
My viper LTX is the exact same way and never had an issue even with the track so loose it would ratchet at one point. Ran it to 117 a few times nothing ever rubbed that.Viper had same mold up the center never had a problem with them
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
You didn't have whatever is in the tunnel up front center 3" or so I bet and can I assume you guys ran 1.630-1.875" studs also??
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
That front part is a louvered vent for the exhaust manifold. The vipers were just open there with the exhaust header exposed to the track. I was running 1.875 studs. I guess if you are going to go crazy long on them there could be an issue but there is a lot of room up in there. Something to keep an eye on but I wouldn't be too worried.You didn't have whatever is in the tunnel up front center 3" or so I bet and can I assume you guys ran 1.630-1.875" studs also??
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes..I figured this was the case...but the metal hangs down 1/2-3/4" ? reducing the net effect of the 1" protector...have you seen this on the SW?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I saw it but looked closer to 1/4 inch to me. I had the skid out last week but didn't measure or even look that close. I'll check it tomorrow and see if I can get an exact clearance on it from the strips.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Thanks!
