Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
With a SW RTX SE to be delivered "any day" as my dealer tells me, I've started to order some accessories, 1 thing I need is storage. The Cat tunnel bag looks a lot nicer that Yamaha's (IMHO) and it just came in. But now I'm scratching my head. The Cat bag requires 2 holes be drilled in the top of the tunnel to secure the bag to the tunnel. I'm thinking this may be a problem with the rear cooler.
Does anyone have better pics of the rear tunnel exchanger? The only 1 on TY that I can see (thanks Mr Sled!) is inconclusive, but I'm thinking I may have no choice but to return the Cat bag and get the Yamaha version. Anyone have detailed insight?
Much appreciated
Much appreciated
141 here. I believe 129 is same.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Well, based on the exchanger running all the way to the back by the flap, I'm guessing the Cat bag won't work. Darn.
Thanks for the pics!
I would think there would be a existing rivet that could be drilled out and used for those little bag mounting nubs. Hopefully they come up with something soon.
Cannondale, are those heat exchanger tubes running the length of the tunnel? And we are suppose to add tunnel protectors on them? Please tell me i'm seeing this wrong!
Yes but they are the tunnel protectors. The additional protectors will only be needed in the rear exchanger if studding. Picture makes them look wider than they are. No wider than the track Windows.Cannondale, are those heat exchanger tubes running the length of the tunnel? And we are suppose to add tunnel protectors on them? Please tell me i'm seeing this wrong!
yamaha06
Do you think I will need tunnel protectors with putting a 1.6" ice cobra track on my ltx le?
**sj**
if your bag is for a tcat and a similar model...I cant see it not working on the sw...they are mostly the same sled?
**sj**
just a guess...but I say you wont need
RX Buck
- Sep 11, 2003
- Grand Rapids MN
- mobilepredictive.com
- 2017 Yamaha Sidewinder LTX
- MN
I am also putting a 1.6 cobra on my ltx! Can't wait
I agree with SJ but I think if it were mine I would put them in even with a nonstudded track just to keep the protector grooves in rear cooler from getting messed up from rocks and stuff. Probably not needed though.Do you think I will need tunnel protectors with putting a 1.6" ice cobra track on my ltx le?
Just looking in accessory catalog and Yamaha does offer the bag that is attached with the nubs on top of tunnel and sides. Medium size expandable for Sidewinder.
swampcat
Same sled, same track, no additional protection. 1900 miles and no problems. Dont know about the S/W, but have a large cat bag on tunnel on a LTX-LE, custom installed with no straps. It is sandwiched to the tunnel with some HDPE and held on with ss bolts and riv-nuts, stratigically placed in tunnel.Do you think I will need tunnel protectors with putting a 1.6" ice cobra track on my ltx le?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I thought the SW's rear exchanger "wasn't" on the TCat/ZR9 - do I have that wrong?if your bag is for a tcat and a similar model...I cant see it not working on the sw...they are mostly the same sled?
I believe it's on all except the Mountain sleds. Both brands.I thought the SW's rear exchanger "wasn't" on the TCat/ZR9 - do I have that wrong?
- 6K
- 47K
