Beenba
My clutch needs machined this year, and been debating clutching it for some time now.
I've been told the 2-speeds with 14.5mm rollers and the black spring is a great setup, but I also know heavy hitters work very well (experience from srx700).
Does anyone have experience between these two on the Nytro?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I run the 2-speeds with Black spring and 14.5 rollers. Pulls like a train.
Beenba
Thanks, over the years I've heard from a few people on here who like that setup. how many km on yours and the weights are holding up well?
apexgturbo
- Feb 9, 2012
- terrenceville
- 2008 Nytro,2009 Nytro mtx,2006 apex drag sled
I run the 2-speeds with Black spring and 14.5 rollers. Pulls like a train.[/QUOTE. Is this with the stock secondary setup.
canoehead
- Jan 14, 2011
- NE, Alberta
I've done about 5000 km's with set-up plus I'm also running a different helix from an Apex
SnoBird888
grab the ulmer or Schmidt bros kit and be done. they set it up fairly close and have all the washers and stuff to add for fine adjustments after
