Dinner
it makes a difference especially on turbos. maybe 5-8 hp "guess". which would be like buying a $700 header for a N/A sled. so if i can make intake temps 30 degrees cooler for 20 bucks of pvc fittings it is worth it. even with the intake next to the exhaust i can really notice a difference when riding in 30 deg weather to 0 deg weather. huge difference noticed with the pants dyno.
Agreed! Mine was above the clutch guard last season for my MPI. On those cold crisp nights, I could notice a difference with how the sled ran. Never checked my intake temps but my seat of the pants dyno noticed it. I changed mine to outside the hood/side panel this season...but we have no snow currently....
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I think your going to notice difference, I did after moving it outside. My intake temperatures are now just a few degrees warmer then current outside air temperature. Let us know when you get some ride time in like to hear your results.
- Nov 29, 2009
- sabattus, maine
Alright keep talking. You almost got me convinced to cut my hood. Lol
yamahaguy
Ride SAFE
- Apr 20, 2014
It was hard make that first cut, I didn't want to at all. But after doing it and riding and noticing a difference I have no regret so no point in hiding it, they will hear if they don't see it. It just plastic after all! Its not like your drilling a hole in a Lamborghini hood.
Dinner
- Nov 29, 2009
- sabattus, maine
Well it's the closest thing to a Lamborghini I'll get.
Staggs I have Blue side panel that has some scuffs and stickers messed up you can have. Stick one of those Ulmer air horns right out the side!
CustomApexMan
On the mcx 270hp kit there is no comparison between in and out of the hood
Groomer08
Dam you guys. So now i hafta add the hurricane cold air intake?
Sucks being a addict.
My friends already think im crazy, why stop now?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
What about pluming it to the nose of of the sled right behind the front frogskin vent? i remember seeing ulmer made something like that for the mpi kit i don't see why you couldn't make one for the hurricane kit. then you would have cold air flowing in wile riding. thats from mr sleds turbo build
My OSP has the intake in the nose and it works great. Its right under the radiator behind the nose frogskin.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Do you know if Ulmer still makes a intake tube like that? Otherwise I'm going to look into finding the intake 90 hose like that and route mine into the nose..any idea what you do with the oil separator hose if it's not on the mpi intake tube?
yamahaguy
Ride SAFE
- Apr 20, 2014
The oil separator hose can just drop down to the belly pan and put the MPI air filter on it that came with your kit. As far as routing the intake up into the nose your kit came with two silicon 90s and 1 silicone coupling plus the aluminum tube that should be everything you need to route up into the nose I would think. If that don't work try large-diameter radiator hose that's pre bent you might be able to cut a section out of it that will work for the route
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
Any one know what to do with the upper separator line? Put the vent foam piece in it? Like the mountain version? Then tie the intake air temp sensor on the left side of the bulkhead?
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I will be putting mine outside but I would like to find a option that didn't have it stuck out easy to take out with a tree or a roll over.
How about like this?
https://scontent-ord1-1.xx.fbcdn.ne...=d2fddd8c8a79b90c923c36d5fe687c07&oe=56EB2FCF
