murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
At what # of boost, that almost double's your powerI was in contact with hurricane and he said to go with bigger injectors
Pc5 pti
And hindle muffler
And I'll increase my mpi trail kit by 35hp
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I am also doing the 21-41 gear swap, I can't find a pic or a price of the d&d can anywhere on their site.That's good to hear!I'm thinking I'm going this route except I might get the d&d muffler instead of the hindle
Along with 21 41 gearing
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ulmer sells them I couldn't find pics either I'm guessing that he must modify the flange. He said 475$ for d&d or 275 for mpi race mufflerI am also doing the 21-41 gear swap, I can't find a pic or a price of the d&d can anywhere on their site.
The d&d alone supposedly give 11 to 14 hp
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
6 lbsAt what # of boost, that almost double's your power
For what I was told the mpi is actually dynoed at 170ish @ factory 4.5lbs
So with these add ons@ 6lbs would put you @ 205hp.
I'd but happy with that kind of increase
Ulmer also has a ecu flash the that he adjusts timing the allows you to run 8lbs that gvies you around 220hp.
I don't think I'm going that route this year
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I was going to do the 240hp upgrade but decided against it. Mine is running so good with awesome gas milage and I'm really concerned about reliability. I do a lot of long distance rides and don't want to be the guy that ruins a trip.
hellflyer
- Dec 2, 2008
Marc! You should get a slp header. That'll give you an increase I'm sure. Spool up is quicker anyway. Dave had a great deal on them in the fall.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
6 lbs
So with these add one @ 6lbs would put you @ 205hp.
sounds about right since a PCV, D@D, and airbox mod would be ~145hp. Add on 40% more power @ 6psi comes in a 203hp. 30% for 4.5psi would be 188hp
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Is that over the trail can or race can?Ulmer sells them I couldn't find pics either I'm guessing that he must modify the flange. He said 475$ for d&d or 275 for mpi race muffler
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
That's over my suitcase trail muffler stock with mpi kitIs that over the trail can or race can?
From what ulmer told me in a email
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I was thinking of that also... you would have to give me directions on setting up fuel with pcv though if you don't mind?Marc! You should get a slp header. That'll give you an increase I'm sure. Spool up is quicker anyway. Dave had a great deal on them in the fall.
I remember you mentioning that you were lean with the header
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Isn't this fun!!!! I can't wait to rip apart my sled again! I actually enjoy working on/modding my sled!
My wife and I went to the NBSSR radar runs last weekend on wanapetie had a blast!
She is all for running my sled in the radar runs next season. It would be fun to see what she can do! ( not for competition just for fun)
hellflyer
- Dec 2, 2008
No problem! Got mine dialed in, header made it pretty lean in certain throttle positions especially WOT so I figure it's got to make more power if it needs more fuel.I was thinking of that also... you would have to give me directions on setting up fuel with pcv though if you don't mind?
hellflyer
- Dec 2, 2008
I wonder if my Hurricane mapping would be close to the mpi set up with header,6lbs and bigger injectors?
Yamadog
I am running 26/44 gears in the 15 XTX with 8 tooth driver and 3.0 pitch and at low boost about 230 ish hp I am seeing as high as 124 mph and have been over 128 with more to go at high boost and the take off is still all I can do to hang on.That's good to hear!I'm thinking I'm going this route except I might get the d&d muffler instead of the hindle
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I talked to Dave and the pc5 will be mapped fromy him for the mods. He knows I'm running mpiI wonder if my Hurricane mapping would be close to the mpi set up with header,6lbs and bigger injectors?
I'm guessing it will be very close to yours or the same...
I will find out though when a purchase the goodies
