ken0la
anyone block off the bottom vent, oil res side? Getting tired of cleaning out ice chunks (following day) after every ride.
Not much air flow to cool anything after area is packed with snow and ice anyway right?
If you've never taken off your side covers after a couple of days of riding in the powpow to inspect #*$&@ like your belt and relays etc, do so man as ice is expanded water and its forces are nasty!
Thoughts?
Thoughts?
gitrdun
herndonp
You could close it off or add frogskins to cool that area that will not allow snow and water in.
http://www.frogzskin.com/index.php?main_page=index&cPath=34_40
Pete
Pete
Nytro-glycerin
- Dec 13, 2014
- 2010 Nytro XTX Black edition
I tried a piece of frogskin that sticks on, didn't last. Still hoping for something to work
herndonp
Most stickons don't last ( extreme cold takes them out)I Believe most of the kits you drill and mount the frame with the frogskin molded into it.
Pete
Pete
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
I drilled and riveted an aluminum frame over that oil tank vent, and alum mesh under the frame. Been there for 5 yrs. I added frogskins to the long side vents, and alum mesh to the two top vents at the same time. I also wadded butyl tape in and around all the front bumper area panel joints ( behind front bumper where the tool kit sat ). I was tired of breaking out junks of ice all through that area. And no more powder through my vents. All my solid state relays are snow free since I did this.Has worked really well. I also used butyl tape to adhere all the vents, except for the aluminum panel covering the oil tank.
ken0la
Thax MP5, this sounds like the way to go, I would however like something that would be easy to remove for the warmer riding in the early spring though. I will continue to ponder this for a bit and will post a pic once I find my solution .
mp5
- Feb 14, 2011
- 09 Nytro XTX
Butyl tape peels right off. Thats the beauty of it.
ken0la
Hell I'll try anything twice! lol
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
I'm using black gorilla duct tape works great rugged stuff
