- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
General
Manual
Service Manual
Stock Sled Specs
Venture Lite & Multipurpose Torque Specs
Engine Tear Down
Bearing Maintenance
Venture Lite vs. Multipurpose
Starter Problem
Starter solenoid and updated fuel pump relay
Summer storage
Fuel and EFI
Adjusting fuel mixture
Clutches
Secondary clutch snap ring fix/mod
Secondary Assembly Video
How to Install a Clutch Kit
Belt/Clutch Maintenance
Reverse Secondary Brainchild Install
Reverse Secondary Install
Chain Case Issues
Testing and understanding Reverse Mechanism
*REVERSE GEARBOX INSPECTION*
Reverse Issue
Reverse Issue 2
Oil Leak
Tunnel
Tunnel Icing
Tunnel Icing 2
Error Codes
Info on Error Code 67
Fault Codes
More Fault Codes
Fault Codes 84
Fluids
Oil change,Front frame removal and starter removal Pics
Chain Case: Which Lube Should/Can I Use?
Handling
Tie Rod End Upgrade
Loose Steering
Loose Steering 2
Steering Kit More
Add Zerks to Spindles
Ball Joint Fix
Ball Joint Fix more
Dogbone Link and Steering Arm fixes and failures
Idler Wheels
Dennis Kirk Idler Wheel Solution with Pictures and part numbers
Polaris Wheels
Ski-Doo Wheels guide
4 WHEEL KIT
Miscellaneous
General Bearing Maintenance
Emblem Falling Off
Dzues Fasteners
Battery Charging when Sled is not in Use
Premium or Regular Gas?
Replacement Bright Light Bulbs
Should I Install a Skid Plate?
What is Engine Breaking?
Y.E.S. Warranty Worth it?
Hitch for Venture Lite
Removing the rear seat
Portable Jump Packs
Skis
Shimming Skis
Electrical/Gauges
How to change the Fuel Pump relay.
Tether Install
Tether Install
Ground Wire Update
Oil Roll Over Kit
Tempertaure gauge install
Suspension
Hyfax Replacement
Removing Rear Skid
Replacing Slides
Tracks
Studding the VL/MP
Studding 2
2" lug track for VL/MP
Review: Camoplast Crossover track
What track fits?
Manual
Service Manual
Stock Sled Specs
Engine Tear Down
Bearing Maintenance
Starter Problem
Summer storage
Fuel and EFI
Clutches
Chain Case Issues
Reverse Issue
Reverse Issue 2
Oil Leak
Tunnel
Tunnel Icing
Tunnel Icing 2
Error Codes
Fault Codes
More Fault Codes
Fault Codes 84
Fluids
Handling
Tie Rod End Upgrade
Loose Steering
Loose Steering 2
Steering Kit More
Ball Joint Fix
Ball Joint Fix more
Idler Wheels
Polaris Wheels
4 WHEEL KIT
Miscellaneous
Emblem Falling Off
Dzues Fasteners
Portable Jump Packs
Skis
Shimming Skis
Electrical/Gauges
Tether Install
Tether Install
Ground Wire Update
Oil Roll Over Kit
Suspension
Hyfax Replacement
Removing Rear Skid
Replacing Slides
Tracks
Studding the VL/MP
Studding 2
What track fits?
Nice job on the Start of the FAQ
- Nov 1, 2009
- 2009 Phazer RTX
Thanks!
If anyone knows of any topics that should be listed here please let me know.
Sled Dog
Well done is right!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
So shouldn't this be stickied? Perfect place for it.
Sled Dog
Done
- Nov 1, 2009
- 2009 Phazer RTX
More info added. Thanks Mooseman for the links!
- 31K
- 46K
- 146K
