1. PLEASE READ: If you have problems logging in with your old password, click the Forgot Password link in the log in screen to get an email verification to request a new password or click Here. If you haven't received a new password from the forum please email your username and password to webmaster@totallyamaha.com. Sorry for the inconvenience.
    Dismiss Notice
  2. All hotmail, msn, outlook, live email accounts are not receiving email notifications. The only way to remedy this is to add @totallyamaha.com to your safe senders list in order to receive notifications.
    Dismiss Notice
Viper Clutching
Discussion in 'SR Viper Talk' started by Schlorven, Jan 3, 2017.
  1. Schlorven
    Schlorven Extreme
    56
    Sweden
    I have a viper 2015 xtx 141 LE whit PC track.
    My current setup is:
    Super tip 50g
    Primary spring O-P-O
    8dn
    Dalton 46/40 helix
    Stock spring and Dalton red spring.
    I have read, "Clutching to the cheap"
    I have some question about the secondary clutch. I have tested the Dalton red in 6-1 and it work OK, but whit the standard pink set in 3-3 i fel that it´s more pull from low end, i don’t se some big change in top speed between the springs, but the snowmobile doesn’t go so fast 120-130km/. "Dead end" comes in 115-120km/h.
    I wonder if it can be some coil binding. is the Dalton helix cut for prevent coilbindning ?
    Can i measure the depth of the two helix and see if they have the same from top to bottom.
    My thought was to put in the stock helix whit stock spring and see where the helix is starting on the buttons, then install the Dalton helix and se if the start are at the same position. If it´s don’t start at the same position can a shim the helix out. is this the right way to go?
    Another question is if the helix ramp should go hole way out when is it full shift.
    Or should i just order the big venom secondary spring that seems to be god according to the "clutching to the cheap"
    I have seen that it´s the G-W-G spring in the COTC kit, this spring has almost the same finish rate as O-P-O but longer, is it a ide to change primary spring and put some washers in?
    i think a have Y-G-Y 40-123 89,4mm long. Longer that O-P-O but 0,4mm shorter than GWG, don’t the same finish but the only it will do is that i must take away some weight, is it any ide to test the YGY?
  2.
  3. Schlorven
    Schlorven Extreme
    56
    Sweden
    Whats the benefit to run a shorter spring in the primary
  4. Schlorven
    Schlorven Extreme
    56
    Sweden
    anyone?
  5. ClutchMaster
    ClutchMaster Pro
    198
    tomahawk
    Country:
    Snowmobile:
    2015 Viper 270 hurricane,
    What R your RPM's at 120?
  6. Schlorven
    Schlorven Extreme
    56
    Sweden
    dont know exactly, but around 9000 and over.
  7. Schlorven
    Schlorven Extreme
    56
    Sweden
    i did find some interesting at the secundary inner sleve, that one that have the glide buttons. I found a little casting edge on the bottom were the spring is compressed against. i grinded it away, but i havint testet it and if it did something. The pic is not from my snowmobile, i found it her on forum and i painted where the casting edge was.
  8. Schlorven
    Schlorven Extreme
    56
    Sweden
    Is it any diffrence between spring possions in the secondary between the dalton red and stock secondary spring. I will try to wrap red spring 3-3 or even 3-2
  9. ClutchMaster
    ClutchMaster Pro
    198
    tomahawk
    Country:
    Snowmobile:
    Actually I would leave more twist in the secondary spring and add a couple grams of tip weight. If you pull twist out you'll lose top end, cause you loose belt tension. You may have to add even more weight but start with 2 grams go from there.
  10. ClutchMaster
    ClutchMaster Pro
    198
    tomahawk
    Country:
    Snowmobile:
    If your looking for top speed mph, low helix finish angle and lots of secondary spring help you get to full shift out. I know this sounds wrong, but it's because most clutch setups slip the belt slightly at full shift out. You need to keep the belt clamp force higher so more tip weight is key
    cannondale27 likes this.
  11. Schlorven
    Schlorven Extreme
    56
    Sweden
    Ok, thanks, i try it.
  12. 09nytro
    09nytro TY 4 Stroke God
    3,414
    grayling,Michigan
    I'm thinking that these 4strokes don't need a Multi angle helx .. I've been really struggling to get this to work right .. With ulmer kit and a sandal muffler weights are empty and 6-1 can only get 8800 topped out and 84 mph.. got overdrive cut in and still can't get it it shift out all the way
  13. ClutchMaster
    ClutchMaster Pro
    198
    tomahawk
    Country:
    Snowmobile:
    If you absolutely positive your not getting full shift out then try a stiffer secondary spring with less initial twist. You will probably have to add more weight, usually in the tip.
Share This Page
