raspybull05
i have an error code on my apex, its code 84. it says that detecting conditions for the T.O.R.S. are satisfied. what does this mean and how do i fix it?
- Jun 28, 2004
- Clinton, Wi.
Throttle Over Ride System. Safety feature that allows you to run wuthout a tether.
Dave
Dave
raspybull05
ok so what can i do to fix this problem? i have put a left hand throttle on the machine and right after doing so the code 84 has popped up?
craze1cars
Is this site flipping out or did I screw something up? Could have sworn I replied to this already. Here's the bypass instructions for TORS on the Apex:
http://www.ty4stroke.com/viewtopic.php? ... light=tors
It's a sensitive little bugger. Since your left hand throttle likely caused the problem, you'll definitely want to ensure you don't have a problem there. Check that all cables are properly routed and nothing's binding up. If you run with TORS bypassed you will have no more safety override...a stuck or frozen throttle will simply put you to your death into the trees since it won't activate...
A tether may be smart in its place, personal risk choice.
raspybull05
Hey guys THANKS a million for your help! it ruined my trip but now i can fix it! very much appriciated!!!!
- Status
