ishpeming fan
Im considering putting a new header on my 2014 viper. MBRP, SLP,EVO,Ulmer. any feed back from someone who has tried any of these headers and any gaines you had in performance . Im running a MBRP trail can as well but I wouldnt be opposed to running a complete exhaust setup either if any of you guys had great results from a complete package set up.
larrypolaris
I have over 2400 miles on the SLP header and can i installed last season. Been holding up great. Definitely a power difference then stock.
ishpeming fan
what clutch setup are you using with your current setup?
Don't forget about the Hindle header...great product. In fact, Hurricanes entire kit has a full Hindle system that includes an airbox mod and mapped PC5 for $1049 US. 17 HP.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
SPI (Straightline Performance Inc.) header here. Only issue is the gasket that comes with the kit. Mine blew out in the first 400 miles and I retorqued the head bolts after EVERY ride for the first 300.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I have the Ulmer header (same as SPI), I did feel more power through the butt dyno, and my turbo spools a lot faster as well. I agree with tapex_07 ditch the gaskets that come with it they have a be re tightened after EVERY ride(like he said for the first 300 miles). After about 1000 miles on it I can still go out after each ride and tighten each bolt 1/16th-1/8th of a turn. This summer I will be swapping them out for stock gaskets. Over all awesome product, well worth the money.
larrypolaris
I have Hauck VP weights with his primary spring. His green secondary spring with a 45/39 helix. 6-1 wrap.what clutch setup are you using with your current setup?
ishpeming fan
thanks for all your input fellow TY members, I have just ordered the venom header from Ulmer racing for sale 399.00 Alan says around 5 hp with header. should work well with my ulmer clutch kit and mbrp trail can. So you guys are saying a stock yamaha gasket should be used with header install? thanks again
tapex_07
- Feb 15, 2009
Correct, at least between the Head and header.thanks for all your input fellow TY members, I have just ordered the venom header from Ulmer racing for sale 399.00 Alan says around 5 hp with header. should work well with my ulmer clutch kit and mbrp trail can. So you guys are saying a stock yamaha gasket should be used with header install? thanks again
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Yes factory gasket. I put the thick gasket on when I purchased the header. Blew it out first ride.
ishpeming fan
Just got my ulmer header today and it came with the factory gasket and can gasket with genuine yamaha part numbers and packaging. It figures seeing as I just ordered a yamaha gasket on line 2 days ago! LOL same exact part numbersYes factory gasket. I put the thick gasket on when I purchased the header. Blew it out first ride.
