niko
Guys im getting a whinning noise when i back off the throttle and the sled comes down to a slower speed. Is this normal? Its coming from the engine area.
niko.
niko.
YAM182
- Dec 19, 2003
Belt/clutch noise from-
Front clutch opening.
Secondary closing.
Secondary closing.
madsledder
- Apr 30, 2006
- Creston B.C.
- Yamaha
could be your chain tension
niko
chain just got done a few weeks ago when i did the reverse. Its in as per the manual so im not sure its that.
Could be the track tension? any way to check it with out a weight scale?
niko.
niko.
Dano
could be your brakes making a bit of contact with disk? Spacers all where they're suppose to be? Did you change the chain or gear to aftermarket? A small gear/chain pitch difference makes a high pitch whine as well.
Dan
Dan
niko
hi dan, ive used the old chain with the new reverse kit so im not sure if thats a factor.
with the brakes im not sure if they are rubing as the noise is only when i slow down. Really it might just me hearing things that are normal(lol)
Im not sure about the order of the spacers too???? theres a little play in the brake shaft about 1mm
niko.
niko.
