zappa
My '03 RX1 Mountain won't start after sitting up over the summer. It's firing, but not getting any fuel to the cylinders.
It's getting fuel to the fuel pump (... are those 2 stacked fuel pumps on the left side of the engine?) but none coming out of them when I turn the engine over. As I recall, the last time I rode it in April I thought it was running out of gas when I parked it.
Any ideas on how to check for the problem?
Newcastle Scott
What do you mean about "It's Firing" Are you saying it has spark or it's sputtering for moments but won't stay running?
zappa
The spark plugs are firing (sparking), so I don't think it's an electrical problem.
markgyver
yea they take awhile to get fuel up.
choke it wide open....if she starts and then shuts off...check them carbs and pilots...
LazyBastard
There's a fuel tank vent line that connects onto the frame on the left side behind the secondary clutch. Yank it off and BLOW into it (with your mouth), pressurize it as hard as you can that way, then PLUG the hose and crank it with the choke on.
black john
hard start
like lb said thats the cure for the first start of the year. and after doing carb work
mmmkokanee
usually i prime a motor thats been sitting for a long time with some gas in the carbs or spark plug holes...
after re-jetting, i started my sled with a propane torch in front of one of the carbs (not a lit torch though!)...it will fire enough on the propane to prime itself and start running...do this at your own risk though!!...don't want to cause a small explosion...i just didn't have any gas around to use at the time...carb cleaner can work too
LazyBastard
Engine won't run on carb cleaner. Quick start will run it. Also acetelene gas is good.
whits-end
Safest way is like LB said: blow in the vent line to pressurze the gas tank. If it's low on fuel, it'll take a fair volume of air to pressurize it . Hold the pressure in with your thumb, and watch to see the fuel travelling thru the lines. Do it again. When you think the carbs are full, crank it with full choke. It still may take quite a bit of cranking. Be glad you've got key start; with my old 2-stroke Yammies, I'd sometimes pull my arm off with the 1st after- storage start.
LazyBastard
Good luck in seeing the fuel flow with opaque fuel lines
zappa
Thanks for the tips. I finally got it going. I filled the lines to the carbeurators with gas, put a little in each carb and pressurized the the tank and it fired up.
Now all I need is some snow. But it's cold enough now that the lakes are starting to freeze.
Ski-Dog
I still don't get this. If my sled sits for 3 weeks or more I go through this. Are these fuel pumps too weak? My dealer doesn't have an answer to this problem so he coming to pick the sled up as it hasn't run for a while and is sure to cause grief and play with it.
I'll see what he comes back with.
I think the answer is an electric fuel pump.
Wilson
Maybe it needs a new fuel pump ,I would just start it more often . My buddy starts his every three weeks all summer and has never had a problem .
